20 Most Recent
Bugaboo Frog - Black Stroller Questions & Answers
I require new plastic clips on straps or just
For a secondhand seat base you could try Buggypitstop in the UK or Karlisle's in Australia a google will find them. You could just laminate a bit of thin plywood to your base. Mountain Buggy use the same clips and do sell them as parts shop.mountainbuggy.com/parts/pre-2010/swift/complete-harness this does require a local seamstress to fit as you have to unpick the webbing and then re-sew it. The clips are actually made by YKK a huge international zip manufacturer, do a google there may be a local agent,
How can you change the straps on a bugaboo frog
The straps are built in and Bugaboos solution is buy a new seat. The Bugaboo uses the same plastic buckle components as the Mountain Buggy, Mountain Buggy sell these as separate parts. If you want to unpick the buckle end and sew back new buckles thats the most economical solution. YKK the international Zip maker also have similar buckle systems.
