20 Most Recent
Acer Veriton L480G Ultra-Compact Desktop PC (Black) (PSVA103040) Questions & Answers
When power switch on the PC,only no signal display is coming on the screen. pl tell me how fix it up.
First check to make sure the video cable is properly inserted (also make sure that it is in the correct port - some PC's have two video ports - one integrated into the m/b and another added to the slot)
Try going into the BIOS to see if the video is working at all (try tapping on the DEL key when starting up) When in the BIOS check to make sure the correct video port has been selected
Sometimes some monitors can be reset by unplugging them, holding the power button for 15 seconds and then try powering them up.
When switch on the pc,no signal deducted display the screen is coming.
Then there is no output from the graphics card.
This needs replacing, as there should always be some output, even if it is wrong!
Try pressing F8 on start up. This will eliminate the graphics drivers and default to a plain VGA configuration and see if you get a display, if so your graphics drivers need changing.
If you get no display then the graphics card needs replacing.
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
How do i install an ssd to replace hard drive
The drives will usually come with a utility to copy your old drive to the SSD and make the SSD the bootable drive. You just need to have both drives connected at the same time. Check for download instructions in the packaging with the drive or check the manufacturers website.
Desktop wont start up
Need more info here please. What kind of computer is there any beep. Try to unplug your computer then while it's unplug hit the power button. Then plug Back in see if this helps
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
How can i reset my administration password if i
Use your windows disk and reset the password from there.
2. Boot into safe mode (using f8 at startup) and you will be logged into the built in admin account where you can change the other admin passwords.
3. Use the free Trinity Rescue Kit to recover the admin password.
