20 Most Recent Audiovox DS9106PK 9 in. DVD Player Questions & Answers
I just purchased a DS9106PK
The source button is used to switch video source such as the video input at the back or the vdeo at the built in player.TV tuner ..Just like the amplifier reciever it is called as auxiliary input selector.thank you.
7/28/2011 12:40:46 PM • Audiovox... • Answered on Jul 28, 2011
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
  1. Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
  2. Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
  3. Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
  4. Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM • Audiovox... • Answered on Feb 16, 2023
I bought a HDMI to AV converter so I can use my Roku on my Audiovox KLV3913 TV, since there is no HDMI connection. I can't seem to get it to work!! Help!!!
Unfortunately, you are probably dealing with a copy protection issue. The digital handshake can't be returned by your KLV3913. You get the same issue if you connect a HDMI source (Blu-ray player) to a VGA monitor. I wish that I had better news for you. Cindy Wells
12/6/2022 5:27:22 PM • Audiovox... • Answered on Dec 06, 2022
2answers
I have an Audiovox VE927 under cabinet tv/dvd/radio combo. I have no sound. Is there a sound board in this unit that could go out?
It's all one board, chances are your audio output IC has failed and needs replacing
8/7/2022 6:55:56 AM • Audiovox... • Answered on Aug 07, 2022
I have a Audiovox d1988 and the screen won't play. I have sound but no picture. Help!!!
Jim, First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you. Hope this helps, Best regards
3/8/2019 11:36:14 PM • Audiovox... • Answered on Mar 08, 2019
Remote for my Audiovox car DVD player will power system on/off, but none of the other buttons work. Its a new system & worked at first. I replaced the battery, but still not working.
I I had a similar problem. What worked for me, was resetting the player. By pressing the picture button on the player itself three or four times I got to the reset option. Press play when it says press ok to reset. My remote automatically started working at that point. Hope this works for you
11/6/2018 2:25:36 AM • Audiovox... • Answered on Nov 06, 2018
I have a 19 audiovox LCD TV + DVD model # LCD1900 w that is telling me Menu locked, Enter Lock Code 4 digit. I have no idea what the code is. How do I get around this?
are you using the right remote, one time i tried to change things and come to find out it was on the dvd not the tv
9/7/2018 4:28:30 AM • Audiovox... • Answered on Sep 07, 2018
Looking for code to use universal remote on 12v. audiovox TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device
12/14/2017 9:52:31 AM • Audiovox... • Answered on Dec 14, 2017
Audiovox DS9106PK 9 in. DVD Player Logo
1 questions posted
Top Audiovox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Televison & Video
Most Popular Question
just purchased ds9106pk
  • Televison & Video
