One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach frrom motherboard to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working hope this helps you
you would either format or delete all of the data from this drive if it has an operating system on it you would format it you have to format your hard drive using a third party disc to erase everything on your hard drive During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system note after you have loaded the operating system you should go back and change the first boot device to your hard drive The BIOS is AMI. Under ADVANCED SETUP: The options listed for 1st,2nd ,3rd Boot device include:IDE0 means Pri master IDE1 means Pri slave IDE2 means Sec master IDE3 means Sec slave
or if you are using a USB insert your usb drive click start right click on my computer select open you should see your USB drive right click then select format another way is to control panel administrive tools,computer management disk management right click on your drive select format hope this helps you www.WipeDrive.com
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also check the Cmos battery and computer ram make sure they are securely seated another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system information all of your computers information will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
43 questions posted
33 Questions
33 Questions
21 Questions
9 Questions
13 Questions
