20 Most Recent
Sherwood RV-7050R Receiver Questions & Answers
Speakers crackle intermittently
There is big chance that the internal wires on the speaker is loose or dust is starting to build up inside.
If your speaker is out of warranty already, you can use the Radio Shack contact cleaner to clean the internal portion of the speaker. Disassemble the unit, make sure it is powered off and then apply the cleaner. Wait for the cleaner to fully dissolve and then you can power on the speaker again.
Let me know how it goes.
Lyzmorato
Fixya Premium Expert
1/12/2010 10:13:25 PM •
Sherwood...
Answered
on Jan 12, 2010
Will not produce sound through the top end of my speakers,
While this may sound strange, it is not likely the receiver that is the probem, at least at this point. Remove the "tweeters" from the speakers and measure across the two leads. You should read continuity. If not, then the tweeters need to be replaced. I believe that you may have blown the tweeters.
Dan
2/7/2009 2:38:39 AM •
Sherwood...
Answered
on Feb 07, 2009
Sherwood AX7030-R
I have a number of suppliers that can deliver internationally or are located in Europe. If you can list the part, I may be able to locate a few alternatives that might be more readily available as well.
Dan
1/5/2009 10:40:31 AM •
Sherwood...
Answered
on Jan 05, 2009
Sherwood Rd-6505 hisses from both speakers
The soft hiss that you are hearing from both speakers of your Sherwood RD-6505 may be caused by a few different factors:
- Ground loop: A ground loop occurs when there are two or more devices connected to a common ground, causing a voltage difference between the grounds. This voltage difference can create interference, resulting in a hissing sound.
- Faulty cable or connection: Check all of the connections and cables between your audio source and the Sherwood RD-6505. Make sure that they are plugged in securely and that the cables are in good condition. A faulty cable or connection can create interference and result in a hissing sound.
- Amplifier issue: The hissing sound may also be caused by an issue with the amplifier circuitry in the Sherwood RD-6505. If this is the case, you may need to take the device to a professional for repair.
- Power issue: If the power supply of the Sherwood RD-6505 is unstable, it can also result in a hissing sound. Check the power supply and ensure that it is providing the appropriate voltage.
If you have checked all of these potential causes and are still experiencing the hissing sound, it may be best to contact a professional for further diagnosis and repair.
My Sherwood 525 receiver only displays the fm input option when rotating the input knob
and FM is dead,? (other shoe drops now)you meant/?Sherwood Newcastle R-525 sold new in 1990s so near 30 years is a good run. no?it needs work, the knob shaft broken installed wrong.no photo of yours posted.,well of FM is dead the problem is far far worsebad power supply DC inside,to fix that needs the shop manual schematic and a meter check each DC power rail for in spec.voltageor if one is shorted to ground. overloading itor the rig got wet, just found this in a garage sale or ran 25 years and die this week./not history told and there are always a story.some even sordid. (full of mouse peeee from attic storage>????? seen it all and some wished not.
Sherwood RD 6506 - centre speaker not working
If the speakers work during the test, then the issue might be with how surround sound is programmed on your tv. You should look into your sound settings with your tv's remote. Thank you.
