20 Most Recent Sherwood RD-6105 Receiver Questions & Answers
2answers
My Sherwood RD-6105 shuts off
It's acting as if a short or near-short exists on the amp outputs at medium levels.
Disconnect one of your speakers at a time and try it. Make sure your speaker wires are tight and not shorting to anything and all channels have 6-ohms or more load.
9/25/2023 2:58:37 AM • Sherwood RD-6105... • Answered on Sep 25, 2023
3 out of 5 of my speakers aren't working. They stopped working after listening to loud music. I believe it might be the output transistors. Can anyone help?
Sounds like the transistors in amp died due to too much stress. Off to repair center ...
4/7/2014 9:48:17 AM • Sherwood RD-6105... • Answered on Apr 07, 2014
2answers
I have a Sherwood Audio/Video
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
10/17/2011 8:17:07 AM • Sherwood RD-6105... • Answered on Oct 17, 2011
I have either the Rd
The remote is RM-103 or RM0105 depending on your receiver model.
This place claims to have one of each for $59 plus shipping...
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=RD6105&brand_pn=SHERWOOD_RD6105&mode=large&uuid=A13041681796481
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A13041681796481&smodel=RD6500&brand_pn=SHERWOOD_RD6500
This auction on eBay has the whole RD6500 receiver and remote starting at $50 ($35 shipping)...
http://cgi.ebay.com/Sherwood-RD-6500-5-1-Channel-500-watt-Receiver-/330556089647?pt=Receivers_Tuners&hash=item4cf6ada52f
If it was me, I'd snipe it at the last 10 seconds and have a spare receiver.
4/30/2011 1:01:29 PM • Sherwood RD-6105... • Answered on Apr 30, 2011
What does the FL-CS-RF mean
Front Left, Center Speaker, Right Front. You may adjust volume level on each with the channel levels buttons -/+ directly under on the remote
4/13/2011 1:08:15 AM • Sherwood RD-6105... • Answered on Apr 13, 2011
2answers
What is the remote control code for Sherwood
Sorry there is no code for the sherwood receiver. You will need to do a code search in the manual here is how.
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for.
Or go to the manual here.
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/grayokselect.pdf
3/2/2011 3:43:54 PM • Sherwood RD-6105... • Answered on Mar 02, 2011
No signal while watching a dvd
You may be experiencing a copy guard protection, there are some products on the web that may help you fix this problem. I would recommend a product called GoDVD. You can look for it on the web. This device will eliminate any copy guard that your DVD is putting out and allow you to watch your DVD’s on your television.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
1/9/2010 3:35:39 PM • Sherwood RD-6105... • Answered on Jan 09, 2010
Comes on and goes right back off
one of three things could be happening:
1. the most likely problem is that the impedance in the speakers is too high, causing a short
2. a faulty mechanical relay, there are two - 1 on the PSU and 1 on the main chip. the relay on the main chip may be faulty
3. there could be a problem with one or both of the main capacitors. the two caacitor responsible are huge and hard to miss you can order them from jay car pretty cheap!
5/3/2009 4:39:27 AM • Sherwood RD-6105... • Answered on May 03, 2009
I have a Sherwood RV 7050R amp which is running hotter on one channel.Does anybody know where I could get a service manual from.Thanks.
You may be able to find a service manual for your Sherwood RV 7050R amp on the manufacturer's website or by contacting their customer support. Alternatively, you can search for third-party websites that offer service manuals for various electronics. Just be sure to use caution when downloading from unknown sources to avoid any potential risks.
2/26/2023 3:22:12 PM • Sherwood Audio... • Answered on Feb 26, 2023
Sherwood Rd-6505 hisses from both speakers
The soft hiss that you are hearing from both speakers of your Sherwood RD-6505 may be caused by a few different factors:
  1. Ground loop: A ground loop occurs when there are two or more devices connected to a common ground, causing a voltage difference between the grounds. This voltage difference can create interference, resulting in a hissing sound.
  2. Faulty cable or connection: Check all of the connections and cables between your audio source and the Sherwood RD-6505. Make sure that they are plugged in securely and that the cables are in good condition. A faulty cable or connection can create interference and result in a hissing sound.
  3. Amplifier issue: The hissing sound may also be caused by an issue with the amplifier circuitry in the Sherwood RD-6505. If this is the case, you may need to take the device to a professional for repair.
  4. Power issue: If the power supply of the Sherwood RD-6505 is unstable, it can also result in a hissing sound. Check the power supply and ensure that it is providing the appropriate voltage.
If you have checked all of these potential causes and are still experiencing the hissing sound, it may be best to contact a professional for further diagnosis and repair.
2/26/2023 6:02:34 AM • Sherwood Audio... • Answered on Feb 26, 2023
Sherwood RX-2030R receiver within minutes after powering on blows fuse F103. What is this fuse protecting as something is obviously failing. Trying to determine what needs to be fixed.
The service manual is here Manual: RX2030R SHERWOOD (archive.org) Moving on, are you sure the 120/240 voltage select is set correctly? That fuse is not listed but could be one of the fuses shown in the schematic on the voltage selector board. You need to check the diodes that are after the transformer to see if one or more have failed. Usually the thermal fuse in the transformer will fail and none of the other ones will. You need to check the transformer for shorts on both the primary and secondary side. You need to see if any of the filter capacitors have failed.
8/29/2022 6:52:53 PM • Sherwood Audio... • Answered on Aug 29, 2022
My Sherwood 525 receiver only displays the fm input option when rotating the input knob
and FM is dead,? (other shoe drops now)you meant/?Sherwood Newcastle R-525 sold new in 1990s so near 30 years is a good run. no?it needs work, the knob shaft broken installed wrong.no photo of yours posted.,well of FM is dead the problem is far far worsebad power supply DC inside,to fix that needs the shop manual schematic and a meter check each DC power rail for in spec.voltageor if one is shorted to ground. overloading itor the rig got wet, just found this in a garage sale or ran 25 years and die this week./not history told and there are always a story.some even sordid. (full of mouse peeee from attic storage>????? seen it all and some wished not.
8/10/2022 9:08:38 PM • Sherwood Audio... • Answered on Aug 10, 2022
Sherwood RD 6506 - centre speaker not working
Hi, If the speakers work during the test, then the issue might be with how surround sound is programmed on your tv. You should look into your sound settings with your tv's remote. Thank you.
5/30/2022 12:12:04 AM • Sherwood Audio... • Answered on May 30, 2022
I have Sherwood RA-1140 AM/FM Receiver Surround Sound, and the surround doesn't work. Can it be a fuse please?
Question edited for full make model (what it is). If the whole unit isn't working, yes, I could be a fuse. If only the surround sound isn't working, it is a wiring issue or a button issue, or an internal component failure. https://www.google.com/search?q=sherwood+ra-1140+service+manual ..
3/31/2022 8:53:02 PM • Sherwood Audio... • Answered on Mar 31, 2022
I plugged in headphones to sherwood reciver rd6506 and only one side works then plugged them into computer and both sides work, both speakers works when head phones are not plugged in
The head phone jack in the Sherwood receiver has dirty contacts. If the head phones work in another device, that proves there is nothing wrong with them. When phones are plugged in the Sherwood, shows s problem with the receiver. When the head phones are not plugged in and both external speakers come on, it means nothing regarding head phones. Contact cleaner could be used to fix the problem.
1/19/2022 2:09:36 PM • Sherwood Audio... • Answered on Jan 19, 2022
Sherwood RD-6105 Receiver Logo
19 questions posted
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sherwood Audio Players & Recorders
Most Popular Question
remote control code sherwood
  • Audio Players & Recorders
