20 Most Recent
Peg Perego John Deere Front Loader Questions & Answers
Peg Perego Thomas The Train - Ride On wont go but horn &whistle works
If the Peg Perego Thomas The Train ride-on is not moving but the horn and whistle are still working, it's likely an issue with the motor or the gearbox. Here are a few troubleshooting steps you can try:
- Check the battery: Make sure the battery is fully charged and properly connected. If the battery is old, it may need to be replaced.
- Check the wiring: Inspect the wiring for any damage or loose connections. Ensure that the wiring is properly connected to the motor and gearbox.
- Check the motor: The motor may be burnt out or malfunctioning. Use a multimeter to test the motor and see if it's receiving power.
- Check the gearbox: The gearbox may be jammed or worn out. Inspect the gearbox for any damage or obstructions. Try lubricating the gears with some WD-40 to see if that helps.
If none of these steps resolve the issue, it may be best to contact Peg Perego customer service or take the ride-on to a certified repair shop.
Peg perego smoking
I would suggest taking it into a service center
8/25/2017 7:50:43 PM •
Toys
Answered
on Aug 25, 2017
We have a Peg Perego
the batteries for the sound go under the steam stack up front, and the 6v sla goes under the seat
8/17/2017 2:36:56 PM •
Toys
Answered
on Aug 17, 2017
My peg perego fire chief
check the battery with a multimeter and see if its showing the correct volts
8/17/2017 2:35:49 PM •
Toys
Answered
on Aug 17, 2017
