20 Most Recent
Teac RC-L2 LCD Touchscreen Remote Control Questions & Answers
Universal remote URC-22B
1051 1005 13501054 1231 12191225 1274 11321217 1032 11581003 1267 1178These are the codes to check with Teac TVs. If you wish to get more, check these sites. Setup code to Teac & Dual Teac are the same.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
I DONT SEEM 2 HAVE A CODE
There is no such thing as a 'universal' remote.
Unless it is a 'learning type,' the code set is fixed when the remote is made and later sets may not have more than a couple of functions or none at all.
My screen for teac lcd tv/DVD combo lcd1001m has gone dark, is there a way to fix this
If the screen for your TEAC LCD TV/DVD combo has gone dark, there are a few things you can try to fix it:
- Check the brightness settings: Make sure that the brightness setting on the TV is not turned all the way down. This can happen accidentally, and adjusting the setting may solve the problem.
- Check the power supply: If the TV is not receiving enough power, the screen may not light up properly. Make sure the power cord is plugged in securely and try using a different outlet.
- Check the connections: Check all the cables and connections between the TV and any other devices. Make sure they are plugged in correctly and that there are no loose connections.
- Reset the TV: Try resetting the TV to its factory settings. Consult the user manual for instructions on how to do this.
If none of these solutions work, there may be a hardware problem with the TV and it may need to be repaired or replaced.
How do I tune my teac led/lcd digital tv model no:le32a321 without a remote
Here are some steps to tune a Teac LED/LCD digital TV without a remote:
- Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
- Use the arrow buttons to navigate to the channel setup or tuning menu
- Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
- If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
- Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
