20 Most Recent Thomson DPL909VD System Questions & Answers
No voltage
Thomson DPL909VD... | Answered on Feb 02, 2011
check for any fuse blown or power supply operation.
give mfg and model to rearch for a diagram on web.
Thomson DPL909VD... | Answered on Dec 29, 2010
if no lights or standby light the power supply inside the main unit has failed best repaired by service engineer. if in uk spares available from www.tvs-services.com
Thomson DPL909VD... | Answered on Aug 11, 2010
Can anyone help me solve a problem with my Thomson DT16300? The orange light stays on. The fan comes on and off at the back. There is no picture and I can not programme it. I have tried rebooting but can't get it working apart from the orange light coming on and the fan starting up.
Thomson DPL909VD... | Answered on May 24, 2009
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Thomson DPL909VD... | Answered on Feb 09, 2009
As you know, this machine should support div-x as standard, in fact it should play just about anything except new HD disc formats.
So you put in a data disc with dix-x files, what happens?
Thomson DPL909VD... | Answered on Jan 10, 2008
If the "check speaker" is always turning on, it is possible the amp itself is shorted at the IC. Replace AMP IC pack or if it has N and P channel output transistors acheck them. Some amps do use a thermister and this could be burned open in circuit.
Thomson DPL909VD... | Answered on Apr 12, 2007
Hello Jan, tell us what model is your portable CD player Thomson
I wait your answer
Greetings Franco Dosil
Hola Jan, comenta que modelo es tu portable CD player Thomson
Espero tu respuesta
Saludos Franco Dosil
Thomson Audio... | Answered on Jun 18, 2019
Murdo's tip to trim off the cover of the AA battery base to expose a few mm of metal is spot on. Replacement rechargeable batteries for my Thomson wireless headphones did not charge, no green light, utterly frustrating, till I read Murdho's suggestion. Thanks for that
Thomson Audio... | Answered on Oct 02, 2018
A "Remote code" for what "device" to talk to your thomson x101b??
Thomson Audio... | Answered on Feb 10, 2018
http://www.thomsonaudiovideo.eu/
It might be a french product . Not sure if you need to speak french but you could ask them if there is a user manual ?
Maybe use a translator web site and put french in as well in your request .
Thomson Audio... | Answered on Jan 25, 2018
Thomson DPL909VD System Logo
Popular Tags
17 questions posted
Top Thomson Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
thomson dt16300 freezing problems
  • Audio Players & Recorders
