20 Most Recent Thomson RCA Bookshelf System with 128 MB MP3 Player, RS2052 Shelf System Questions & Answers
Try this... unplug the unit and turn it upside down.  Have a small screwdriver ready.  No plug the unit in and try to turn the wheel in the large slot clockwize.  When you see the spring clip try to grab the white plastic stop and move it clockwize.  This should eventually open the door.  It did for me.
Thomson RCA... | Answered on Mar 14, 2011
Aux. Is for a device input that you can add to your system.
You have 2 RCA Phono jacks on the back for plugging in the device.
Thomson RCA... | Answered on Sep 02, 2010
Hello, first switch off the system for a while like 30 minutes, then put it on back. You can try and reset it if it has reset functions on it. If that dd not work out, in other to prevent further damage to the player, call a radio repairer to adjust the rubber inside where the cd opener is. It is somehow stiff and it needs to be free a little bit for it to work properly again. Also check the voltage of the light you are using on the system that light affect it to. Take care.
Thomson RCA... | Answered on Apr 20, 2010
some of possibilities are:
a) a burnt out LED (light emmiting diode) inside the display (could be tricky or difficult to change it) or a faulty LED power supply line
b) if the light source is an electroluminescent panel, possibly the panel itself or the power supply is faulty (electroluminescent panels use an elevated voltage power supply which is in the shape of a small box somewhere inside the housing, with two wires going to the panel - it is also possible that the power supply is not in the form of a box but is in fact an integral part of the circuitry).
c) a loose wire contact - check the connectors for any broken wires, oxidation on contacts or loose solder points for connectors on the circuit board
Anyway, these are just possibilities so the trouble may as well be somewhere else in the system.
regards
3rq8 (Triarcuate)
Thomson RCA... | Answered on Jul 15, 2009
You might remove the case and remove the disks. Uplug first.
Be carefully not to force or bend parts. retry
Thomson RCA... | Answered on May 07, 2008
There is a problem with the device itself...what I would recommend you to do is to return it from the store you purchase it...there isnt anything phisycally you can do about the problem you are having...it is the device itself that is defective.
Thomson RCA... | Answered on Jan 27, 2008
Have you tried cleaning the sensor on your stereo, and also the transmitter on the front of your remote? Otherwise check the battery terminals in the remote for corrosion to make sure the batteries havent leaked.
Thomson RCA... | Answered on Nov 27, 2007
Hello Jan, tell us what model is your portable CD player Thomson
I wait your answer
Greetings Franco Dosil
Hola Jan, comenta que modelo es tu portable CD player Thomson
Espero tu respuesta
Saludos Franco Dosil
Thomson Audio... | Answered on Jun 18, 2019
Murdo's tip to trim off the cover of the AA battery base to expose a few mm of metal is spot on. Replacement rechargeable batteries for my Thomson wireless headphones did not charge, no green light, utterly frustrating, till I read Murdho's suggestion. Thanks for that
Thomson Audio... | Answered on Oct 02, 2018
Thomson RCA Bookshelf System with 128 MB MP3 Player, RS2052 Shelf System Logo
18 questions posted
Top Thomson Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Thomson Audio Players & Recorders
Most Popular Question
product aux source wondering
  • Audio Players & Recorders
