20 Most Recent SansuiM1315 TV Questions & Answers
3answers
In sansui television. is not working properly.
dear,i also had suffer from it's service menu code. in some days ago i had been seeing a web site, their was had every service menu.then i got your sansui tv model.your sansui "ctvk2k21"model's in the IC no. is "tda9370ps/n3/a/1932" service menu is press "menu(from remote) & 0,3,2,3(from remote)".for more information call me for in any electronics gagged problem.
3/28/2020 1:25:17 PM • SansuiM1315 TV • Answered on Mar 28, 2020
2answers
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
9/26/2013 6:44:14 PM • SansuiM1315 TV • Answered on Sep 26, 2013
Sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
Check the Flyback Transformerand associated circuits.If 2SK2996 is blown, it may take out the PWM IC and some components that goes with it.Let me know what you find or needs further assistance.
9/23/2012 1:38:33 AM • SansuiM1315 TV • Answered on Sep 23, 2012
Cable tv on a 1315
You have the set in standard air mode rather than cable mode. I am not familiar with your particular model, but you should be able to switch it to cable (assuming that it is cable ready). Check for a switch on the back or front. If there is no switch, there should be a menu option for changing the set to receive either over-air or cable. Check under the setup menus.
Dan
3/3/2009 11:03:33 PM • SansuiM1315 TV • Answered on Mar 03, 2009
2answers
Sansui TVM1915 Sound just quit!
if theres a headphone jack plug in a set og headsets. if the sound is there then you know that your speaker is bad. if its not make sure the volume indicator goes up and listen closely to the speaker. Do you here static noises?? NO? ok then its a problem with the audio output IC built in to the set and this is probably something you cant repalce unless your experenced with soldering printed curcuit boards. If you here staic or a small his then the volume contrpl curcuit or the audio if is defective and this as well is not something you can diagnoise unless you know how to troubleshoot electronics. Good Luck
5/16/2008 12:26:32 AM • SansuiM1315 TV • Answered on May 16, 2008
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
4/8/2008 1:25:18 AM • SansuiM1315 TV • Answered on Apr 08, 2008
Aux channel
Press channel down until you get to channel 1 then press channel down one more time ,this should give you your AUX.If it doesnt try going into the menu and doing an autoprogram with the video game hooked up and turned on.
2/8/2008 3:00:12 PM • SansuiM1315 TV • Answered on Feb 08, 2008
Sansui Model: TVS2542A 27" TV
check line output transformer, look for dry joints
2/8/2008 6:25:01 AM • SansuiM1315 TV • Answered on Feb 08, 2008
Hello
Hi what is your problem explain in as much detail as possible thanks
12/11/2007 10:35:48 PM • SansuiM1315 TV • Answered on Dec 11, 2007
1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
11/10/2007 4:08:04 AM • SansuiM1315 TV • Answered on Nov 10, 2007
Can I program a Sansui television?
It depends what you want to program it into?
How Do I Program My Sansui?
Techwalla https://www.techwalla.com > Tech Support > How To Turn on the television using the "Power" button on the remote control. Press the "Menu" button on the remote to bring up the main menu for your Sansui. Use the ... ..
2/20/2024 5:45:40 PM • Sansui Televison... • Answered on Feb 20, 2024
My Sansui TV has no remote and cannot access wifi
SmartAviator, no other information is required as the question is concise as it is.
1/7/2024 11:58:49 AM • Sansui Televison... • Answered on Jan 07, 2024
Sony PlayStation PS4. How to hook to my 2009 19 inch Sansui television please?
Question edited for clarity. For a definitive answer, the television model number should have been added to check specs.
Can't get video to work on tv. Sansui HDLCD19WB and not ...
JustAnswer https://www.justanswer.com > TV Problems Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ... 1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
Can I connect a PS4 into any LED TV?
Quora https://www.quora.com > Can-I-connect-a-PS4-into-any-... May 3, 2018 - Usually PS4 is connected to a HD TV or 4K TV through HDMI cable which is the most obvious method. PS4 console has HDMI port just for the obvious ... 4 answers · Top answer: Hey man thanks for the request The ps4 console is connected to the tv through an HDMI cable ... Will a PS4 work with any TV? - Quora 9 answers May 26, 2018 Can a PS4 work with a 1366x768 TV (vu 32-inch ... 4 answers Nov 22, 2017 Will PS4 slim work with any TV? - Quora 6 answers Apr 5, 2017 Are Sansui 4k LED TVs any good? How do they ... 4 answers Nov 26, 2016 More results from www.quora.com
12/17/2023 11:11:14 PM • Sansui Televison... • Answered on Dec 17, 2023
2answers
Am connecting a SANSUI TV to a Dish Hopper. No problem with HDM1, but where to land the HDM2 cable at the Hopper?
I have never heard of a dish hopper before, but this tells you how to set them up. A Sansui is probably not the best choice as they are cheap and nasty televisions. https://www.google.com/search?q=Dish+Hopper+connections ..
11/4/2023 11:50:33 PM • Sansui Televison... • Answered on Nov 04, 2023
SansuiM1315 TV Logo
23 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
sansui sv2918 keeps blowing k2996
  • Televison & Video
