20 Most Recent
Wolf Range WKGD-1 Gas Single Oven Questions & Answers
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problemafter power outage. It wouldnt stop beeping with error message relatedto temperature control. My solution was to turn power of at circuitpanel, then reset by pressing and holding the clear button for 5seconds. Also note: in my case I had to close the displaybefore switching the panel off. When I tried to the reset process withthe panel showing, it wouldn\'t reset. To reset othervarious parts of the control panel Instructions said:Time-of-Day ClockImmediately after the oven is installed, setthe 12-hour clock to the current time of day. It may need to be resetafter a prolonged power failure. The clock is visible on the controlpanel during all modes. If the upper oven timer is set, the clock willnot be visible in the upper oven control panel display.SETTING CLOCK1) Touch CLOCK. 2) Touch number pads toset current time of day.3) Touch CLOCK or ENTER to startclock.24-HOUR CLOCKThe time-of-day clock can bechanged from a 12-hour clock to a 24-hour clock. After the clock hasbeen set, touch TEMPERATURE for three seconds, touch CLOCK, and thentouch ENTER. Follow the same sequence to change back to the standard12-hour clock setting.Fahrenheit to CelsiusTheoven can be changed from Fahrenheit (°F) temperature to Celsius(°C).
How do i find the fuse location for a Wolf double oven, Model D030F/S ?
Dear Friend,
Pull the oven towards you, disconnect any electrical cord from the wall. Normally the fuse is located right next where the electrical cord enter in the back of the stove. If there is any panel right on top of where the electrical cords connects to the oven, simple removed that cover and there should be a fuse. If not, removed the rear panel where the electronic control panel is. Hope you can find it!
Good Luck!
