20 Most Recent Brother HL 6050 Laser Printer Questions & Answers
2answers
Brother HL-6050DN Printer gives "replace laser sca...
The problem coming because the laser unit in your printer is not working . Need to be replace laser unit to solve the problem.
1/11/2018 11:39:02 AM • Brother HL 6050... • Answered on Jan 11, 2018
0answers
I installed a new cartridge
Check to make sure you removed all the tape and plastic from the toner that is supposed to be removed. If that is not it, it could be the little connector that reads the toner is dirty or broken. You can try cleaning it off (maybe just dust...try some compressed air) or it could be done for if it can't recognize the new toner.
Also make sure the toner you bought is fully compatible with your model printer.
Good Luck
4/19/2011 5:36:55 PM • Brother HL 6050... • Answered on Apr 19, 2011
Drum & toner were replaced and now the printer
I assume "Prints in charcoal" means dirty printouts. The toner is not staying on the paper?
Sounds to me like a bad "Fuser Assembly" problem.
You can source one from:
http://www.precisionroller.com/fuser-assemblies---units-for-brother-hl6050d/details_38855.html?src=gbps
Hope this helps
3/14/2011 2:45:49 PM • Brother HL 6050... • Answered on Mar 14, 2011
ERROR E50 lors le demarrage
firstly see the power cord if it is working then see the projector power supply output
3/6/2011 7:33:54 AM • Brother HL 6050... • Answered on Mar 06, 2011
My brother hl-6050dn printer shows
The machine has a fuser error and will need to be replaced
2/14/2011 4:18:28 PM • Brother HL 6050... • Answered on Feb 14, 2011
tip
How to get the page count on a Brother HL-6050
To obtain a page count (also called a meter reading) from a Brother HL-6050 printer, follow the steps below. (This procedure also applies to the HL-6050D and the HL-6050DN models.)
A. When the machine is on and ready to print, press any of the following keys to bring up the menu: Set, Back, +, or -.
B. The first menu heading that appears is Information; press Set to select it.
C. Use the + or - keys to scroll through the Information menu until you see Maintenance.
D. Press Set to select it.
E. The first option that you'll see is Page Counter; press Set to view the count.
The number of pages printed so far will appear on the screen. Once you've seen or recorded this number, keep pressing the Back button until you're back at the Ready screen.
If you would rather have a printout with the page count on it, you can get that instead by simply pressing the Set button three times from the Ready screen. The first time you press it you'll bring up the menus, the second time you'll select the Information menu, and the third time you'll select Print Settings. When you choose Print Settings, three pages of information will print out, showing supply usage, jam counters, and machine settings. On the second page, about halfway down the page under the <Device Status> heading, you'll see the page count. Beneath the page count, you can also find the number of pages printed from each paper tray, as well as the page count broken down by paper size (for example, letter-size paper, legal-size paper, or envelopes).
Printer unavailable on list
go to company web site and download the driver
6/28/2010 11:45:16 PM • Brother HL 6050... • Answered on Jun 28, 2010
Printer does not print the last page of a
Check out your setup on Word (or whatever word processing app you are using). Make sure the Print setup is set to all pages. Sounds like maybe it's set to a fixed number.
File>Print>Print Range: All
If you are printing spreadsheets (e.g. Excel) make sure you have set the Print Area correctly.
3/26/2010 9:10:50 PM • Brother HL 6050... • Answered on Mar 26, 2010
My printer HL6050DN give problem ERROR E50, HOE
Its a fuser error.
When you repair or replace the fuser try this, oh its a while since i had this problem so i will give you a rough idea for the fix.
turn on machine and when the red light flashes press the button ten times and this will reset it.
you may have to press the button as soon as it flashes or otherwise after the first or second flash start pressing ten times.
sorry but the brain will not just remember the exact sequence, but you get the idea.
if you are still in trouble you can email me and i will root out my noted for the exact fix.
Tommy. [email protected]
3/25/2010 9:24:38 PM • Brother HL 6050... • Answered on Mar 25, 2010
How to download firmware for brother hl 6050dn,
Site for the hl6050dn, see:
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolaserpri/hl6050dn_all.html?reg=us&c=us&lang=en&prod=hl6050dn_all
Select Downloads.
Under Step 1 click on the word Drivers;
Under Step 2 click on the phrase Windows XP Home/Professional
Under Step 3 click on the language English (or another preferred language)
At last click on the blue Search bar
The Full Driver & Software Package download should contain all the
necessary utilities this printer needs for installation on XP.
Click on More Information, take notice of "How to download and install" on the bottom page of this page:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/000100/dlf000188.html?reg=us&c=us&lang=en&prod=hl6050dn_all&type2=1&os=7&flang=4&dlid=dlf000188
Click on the blue Download bar and at last accept the terms and condition statement. Next the download page will show up for the download of file "6050inst-0103-en.exe".
11/10/2009 1:36:23 PM • Brother HL 6050... • Answered on Nov 10, 2009
What is firmware
Firmware is the directions for how a device 'thinks' (internally)
11/10/2009 10:39:05 AM • Brother HL 6050... • Answered on Nov 10, 2009
2answers
Why brother printer paper jam
I'm not certain of the cause. It may be an accumulation of dust on the roller. https://www.youtube.com/watch?v=wpzSPRXbLh8 https://www.youtube.com/watch?v=WWvO0osJkAc
1/6/2023 7:02:30 AM • Brother HL... • Answered on Jan 06, 2023
Brother HL-1440 Laser Printer makes a loud noise when it tries to print and won't print. All lights are flashing.
Question edited for full 'make model (what it is)' Question moved to Brother HL category. chapter 3 onwards of the manual. The drum light means you need a service call. https://download.brother.com/welcome/doc002127/ZLe_UG_eng.pdf ..
4/23/2022 10:16:51 PM • Brother HL... • Answered on Apr 23, 2022
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
7/30/2021 12:03:45 PM • Brother HL... • Answered on Jul 30, 2021
Brother hl2270dw toner light stays on
Have you tried resetting it? I can't remember all the steps, I see some of the other comments have them but just to be sure you didn't miss anything I suggest you download the manual and go step-by-step. You can find one here - Brother HL-2270DW manual
6/2/2021 6:34:36 AM • Brother HL... • Answered on Jun 02, 2021
Brother HL 6050 Laser Printer Logo
Popular Tags
21 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
HL Brother
  • HL Brother
Most Popular Question
error e50 lors le demarrage
  • Office Equipment & Supplies
