20 Most Recent
Brother MFC-210 All-In-1 Print/ Scan/Copy/Fax and Photo Center - Twenty Dollar Mail-In Rebate Printer Questions & Answers
How do i get the
keep all the sheets of paper one behind the other together in the faxing tray and let the FAX do the rest....
How do i scan anything form the brother all in one
Hi there
You need a program that you can use on your PC with this program you scan it to your PC and then print it out, ok you need a program like art or photo or paint or some thing like this that have a scan in it.
Read more below.
The best program to put on your Pc is what I use and it is Free you, it is called PagePluse SE, you should try it you can do all sort of things with it but there no scan on it, just scan your photos to the your pc with another program witch has scan on it and put them in the SE program and you can do any size you wont and after adding text to it or backgrounds you can send it to the printer and print, an other program I use for scanning from the printer to the PC is called PainShop Pro 7 witch is a old program there newer ones out now but I am happy just using the old one it does the trick.
The
Free version is Called PagePluse SE you not need the version 9.
Ok here the link to download the PagePluse SE program and it not a free trial it a free, there is one you can Buy but this is all you need download the free one it just as good.
Click Link = http://www.freeserifsoftware.com/software/pageplus/index.asp
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
: Pineworks
How to get my printer to print
It may or may not work, but try installing as Administrator and setting the program's EXE into "Compatability Mode for XP SP2",and also, running as Administrator.
Windows 7 just doesn't want to support any hardware over like a year old... Drivers are a HUGE issue. Especially for older stuff. Compatability Mode is one way round it but not always.
Also try installing in SAFE MODE if all else fails, still set Comp mode & run as Admin tho.
It seems to not be receiving a signal from the pc.
you should try replacing the cable however if it is new then you may want to make the sure that you run the cd that came with it on your computer in order fir your product to work properly i hope this helps!
Brother MFC-210 fax issue
Install fax software . You can do this with the following procedure:
go to control panel, go to add and remove softwares and then in install windows components install fax .It will ask u for a windows cd
I have replace all of my ink jet cartridges and it
did you make sure to remove the stickers covering the print heads? double check. other than that you can clean the heads with a qtip and isopropyl alcohol, they may be dirty with old ink and not able to see the new cartridge properly.
INSTALLING DISC FOR MFC210
Hi Ellen, not sure if your problem is that you can't download ar that you don't know where to find the software.
The Full Driver & Software Package can be downloaded from the
Brother website (63Mb).
hope this helps
Albert
Prints java script instead of highlighted page
First, you probably should not stop the printer after it starts printing, it always creates problems. Second, you should clear your browser history and then you should select the range of pages to print on your print properties menu. If this does not work try reinstalling the print drivers.
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
