20 Most Recent
Brother HL 1440 Laser Printer Questions & Answers
Brother HL 1440 Printer Density Adjustment
For sure u can increase the darkness and there are settings to increase but u need to browse through the menu to locate the darkness increasing options. The mannual should definitely help.
Thanks
My printer won't print. The drum light is on (just
You must reset the drum counter. Check the link where you find how to reset the drum counter http://support.brother.com/g/b/faqend.aspx?c=us_ot&lang=en&prod=hl2280dw_us&faqid=faq00002837_000
Best wishes !
How can I get the printer to print when the alarm is on
depends on what alarm is on for ? if its on for say ? out of paper or out of ink then no its not going to print , even if it really has paper and ink , but it thinks it is out it still wont try , paper out switches in the tray do get bent/broken and some mfg wont allow u to use non mfg ink/toner it just gives a fault
The alarm light is on and it won't print
Check the back of the printer. Open up the back door. There is a barely visible 2nd door which you need to open. Check to see if there is a paper jam behind this 2nd door. Often this is the problem and clearing this back paper jam will clear the red alarm light.
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
My copies have dirty gray
remove drum assy. and remove toner unit off drum then blow out the drum only. This should clear problem.
PRINTER DRUM ERROR
The drum unit needs to be replaced as it has reached maximum prints for the drum.
The drum unit is the carriage part that the toner unit sits in before it is put in the machine.
Brother HL-1250 owner's manual
Three Horizontal lines indicates a 'Light Burnt Drum'. The drum units are light sensitive. If they are left in the light too long they will be affected and it will show as black horizontal bars. The number of bars really depends on the circumference of the drum some are 2 some are 3 some can be 5 etc.
Solving this you can only replace the drum unit. Check with your local remanufacturing outlet to source a replacement drum unit at a price WAY better than buying new.
HL-1440 makes a howling noise while printing
sounds you have a noisy scanner ... try disassembling the laser unit and clean the mirror bearing and the axle
but don't expect too much from it ... often is a waste of time....
