20 Most Recent
Sony Ericsson XPERIA X2 a Cell Phone Questions & Answers
How can i reset my sony ericsson xperia x2
Solution 1:
Just do following with your phone:
Windows key > Settings > System > Clear phone memory
This will hard reset your phone
Solution 2:
There is a boot menu that allows you to do the hard reset (or reset to factory defaults) without using Phone Reset utility.
1. Remove the battery
2. Reinsert the battery, be ready to press two keys on the keyboard
3. Once backlight goes on, within 1 second press and hold win-key (top left) and O.
4. In the menu press W to select clean boot
5. Press Win-key to boot the phone.
Forget unlock code for xperia x2
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Sony ericsson ck131not sccept sim card
What message are you getting on the screen when you turn the phone on? Is it recognising there is a sim card there but not letting you use it? The most common reason for this is often a 'Locked' handset. Most networks set the phones the sell to only work for their sim cards. Most specialist phone retailers can usually Unlock the handset for a small fee.
If it isn't recognising that there is a card there it will either be a faulty sim card or a faulty phone.
My sony ericsson t700 internet settings does't install why
This phone was first released in 2008 and Sony's support for mobile phones by an agent is discontinued. In short, calling Sony for support won't help. The T700's technology was GMS/HSPA. T-Mobile and AT & T are carriers which access such. Whether either would assist you with setting up network connections is unknown to me. It sounds like your query involves the basic setup. I would review that in relation to the feature you are attempting to access and then query your carrier. But that route may offer no joy. The user manual has a troubleshooting section Here is the user manual for the T700 but there is a real question of your access to software updates for a 2008 release phone. I have no idea of the veracity of the service that claims to offer repairs or unlocking for this phone. This looks like an exercise in frustration. Sorry.
https://www.manualslib.com/manual/322716/Sony-Ericsson-T700.html?page=65#manual
Block stolen phone using imei
Unless you had an app like LookOut or Prey (highly recommend both) it is highly unlikely. Try talking to your service provider and see if they can track the GPS, otherwise you are SOL.
