20 Most Recent Zenith DVD2381 DVD Player Questions & Answers
When playing a DVD, we experience frequent stops and starts..
It may be a dirty lens, or perhaps the drive is getting stuck.
The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
If it still doesn't fix the issue, then the following steps can be taken.
Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
6/5/2010 5:34:52 PM • Zenith DVD2381... • Answered on Jun 05, 2010
I need to be able to play different regions on my
If your DVD player is not a multi region player you cannot play any other region DVD than the one specified at the back of the player. Check in y our user manual it tell you if it is multi regeon. Multi regeon players are bit more expensive.
1/2/2010 10:24:56 PM • Zenith DVD2381... • Answered on Jan 02, 2010
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Unlock zenith tv from hotel code without remote
The hotel mode is set by the remote control , not the control panel.
8/8/2022 2:43:24 PM • Zenith Televison... • Answered on Aug 08, 2022
Where can I find a manual for my Zenith ZG120M alarm clock
Not available online, but there is a video. https://www.google.com/search?q=Zenith+ZG120M+manual ..
7/22/2022 3:24:38 AM • Zenith Televison... • Answered on Jul 22, 2022
My 50' zenith tv clicks on and then goes right back off after about 2 seconds what's the cause of this?
Without a model there isn't a way to give any helpful information
7/11/2022 11:09:37 PM • Zenith Televison... • Answered on Jul 11, 2022
My 60 inch zenith plasma tv goes off in the middle of watching TV but always came back on but now the screen is black but sound still works
Is the tv blinking a code on the light in the front of the tv. If so go to manualslib.com input the model number and look up the trouble code in the manual for the tv.
5/27/2022 6:29:44 AM • Zenith Televison... • Answered on May 27, 2022
Factory reset my zenith c32v36 tv
Does it work correctly with the remote?
12/24/2021 11:27:52 PM • Zenith Televison... • Answered on Dec 24, 2021
How to program my 1.5 echo tech 113268 remote to operate zenith tvi
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name of your device in its search box at the right column of the display window. It will help you to find the details easily. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/
9/24/2021 12:41:35 PM • Zenith Televison... • Answered on Sep 24, 2021
Reset code for zenith tv model z42p240-ub
Is tv smart tv
8/14/2021 6:23:11 PM • Zenith Televison... • Answered on Aug 14, 2021
I have a zenith sy1951y crt and when im on aux theres an onscreen clock that wont go away, how do i get the on screen clock to go away?
Do you have the remote? If you do, it should have a quit button for menus like that. The remote is either the MBR3457 or MBR3447. It's on eBay for $10. It is possible that both of them may work for your TV model.
7/17/2021 4:01:11 PM • Zenith Televison... • Answered on Jul 17, 2021
I need the universal remote control code for zenith plasma tv z42pj240. my remote is a onn remote
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
3/29/2021 4:25:05 AM • Zenith Televison... • Answered on Mar 29, 2021
Zenith DVD2381 DVD Player Logo
5 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
when playing dvd experience frequent
  • Televison & Video
