20 Most Recent
Zenith XBR411 DVD Recorder/VCR Questions & Answers
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
Zenith dvd/vcr mod #6711R1N211C. Need to prog the volume button.
In my manual, to control a sony TV.. the code is number 8 or number 9.
You will hold down TV POWER, hit 8 then release TV POWER.
If that doesn't work, try number 9. Once the batteries are removed, it resets the code, so write it down. It will also over ride your old codes once you input the new one.
Note: Depending on your TV, some or all buttons may not function on the TV, even after entering the correct manufacturer code.
I looked for the section on Stereo, but all I found was the above.
Hope this helps.
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
Dmr-eh57
Did you try the videohelp solution?
http://www.videohelp.com/dvdhacks/zenith-xbr411/5178
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
