20 Most Recent
Zenith IQB64W10W 64" Rear Projection Television Questions & Answers
Zenith IQB64W10W 64" power problem
Try replacing N-channel mosfet transistor 2sk2518. I had the same problem, and it worked for me. It is located on the convergence board.
Zenith 51" tv
There is a very good chance that the fault can be in the power supply, and or one of the scan circuits are failing, due to a few parts that have come off their values. These types of faults are due to age and use.
You should call in a service rep who is familiar with your make and model of set. He would be able to give you a proper estimate for the repairs.
Some of these repairs are very reasonable in cost, while the more difficult types can be rather expensive.
Hope yours is the first case
Good luck
IQB64W10W high-def problem
Your problem sounds like the digital board and probably was what the repair people said. I would suggest telling them about Tri-State Module, Inc in Evansville, IN. 800.203.7484. They have a good selection of modules for about any set and most are under $150.00 with the average being $100. They rebuild boards and all boards carry a 12 month warranty. You can also access them at www.tristatemodule.com. If they can't help try PTS in Bloomington Indiana. I use them for alot of replacement modules. Same deal as tristate. www.ptscorp.com
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
