20 Most Recent
InFocus Proxima DP6155 Multimedia Projector Questions & Answers
Power button is flashing red
If the projector has given more hours on the lamp it can be a faulty LAMP .
Also it can be due to a faulty filter that is clogged and so the air flow being resticted can sut down the main circuit. You need to remove clean and reset.
Finally a fault in the power section or the mother board can also relate to the same issue.
take consensus and confirm.
Thank You
Power button is flashing green,
I had the power on and off cycling issue described in another post and when I reassembled the projector I forgot to plug the two wire plug back into the power board. The power light flashed. I removed the top cover and plugged it in and the projector is now working perfectly.
Lamp wont stay on
this family of projectors have an issue with the edge connector from the power supply to the main board. the edge of the power supply board (that fits into a connector on the main board) has solder "fingers" that get pitted and start to lose conductivity. resolder them and take a jewlers screwdriver to scrape the pins inside the connector and slightly bend the pins inward to insure a good connection. if you aren't so good at soldering, you could always send it in to an infocus service center for repair. try
www.avsolutionsny.com. they're really good.
Bulb hours?
The lamp timer hours can be found at the very first thing in the "ABOUT"menu
Cheers
ALIGNMENT Problem
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Color Alignment
reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
