20 Most Recent
Bose Lifestyle SA-3 2-Channel Amplifier Questions & Answers
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Bose SA-3 Amp / Blown Fuse
The problem is not the transformer. You now have shorted output transistors at the very least. By corssing the wires you presented a zero(0) ohm impedence load to the output section. It quickly went into overload. Before the fuses had a chance to open up, the outputs fried. This unit will require new output transistors and perhaps the previous driver circuit will require parts as well. Figure on $20-$50 in parts plus hte local labor rate for the repair.
Dan
Not work with media ceter
Before somebody can help you you need to give us the make and model number. You have the unit and know what it is, we don't. Also What media center are you talking about. what else is connected, and define not work!
SA3 amplifier to move to Europe : capability of the transformer ?
While living in the States I purchased a Bose Acoustimass 10 system but have now moved back to the UAE. As the system operates on 115 volts ONLY I would like to get it work on 240V without having to use a step-down transformer. By changing out the transformer form 115v to 240v will it work or will I have to change any other components within the system. Can anyone help me??
Bose as-3
You need to change the internal transformer, it is not simple unles you have some electrical knowledge, I made the same mistake and ended up selling the us one and buying a 240v one
Where is fuse in Bose SA-3 Amp
If there is not an external round push and turn style fuse port then it is in the unit itself. You will have to take it apart.
