20 Most Recent Lexmark F4270 Plain Paper Inkjet Fax Questions & Answers
Multiple documents do not feed correctly in the HP
My Lexmark F4270 wont print and show error1203
11/7/2013 9:31:15 AM • Lexmark F4270... • Answered on Nov 07, 2013
My printer does not print
Hi,> Install proper drive in you printer number.> Clean virus in PC.> Printer data cable check another printer, if cable not ok then problem solved.> Check printer print setting option.> Printer print LED active mode check. If not active mode not print output.> Power section proper working or not.More Technical Support Visit and call now.Thanks..
9/6/2013 2:38:26 PM • Lexmark F4270... • Answered on Sep 06, 2013
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
6/17/2013 1:12:42 PM • Lexmark F4270... • Answered on Jun 17, 2013
THE UNIT SHOWS ERROR CODE 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
11/20/2012 9:55:57 PM • Lexmark F4270... • Answered on Nov 20, 2012
How to remove cover on lexmark F4270
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
3/15/2012 8:14:39 PM • Lexmark F4270... • Answered on Mar 15, 2012
0answers
Do I insert the paper I want to fax face up or
Having no Operating Guide, I'd type a one line sample, make a note on the paper like "face-up" and put it in with the paper facing up and hit "print".
If it prints on that side you have your answer. If it prints on the backside, then put your papers in facing down.
6/20/2011 5:59:49 PM • Lexmark F4270... • Answered on Jun 20, 2011
We have no dial tone and a fax will not go through
check ur line is current passing through the line or not if not check or find the breakage
3/16/2011 4:02:55 PM • Lexmark F4270... • Answered on Mar 16, 2011
The fax can not recive
Is your line fax enable? If not, definitely you cannot receive fax just sending only. Check you telephone provider.
3/9/2011 1:26:23 PM • Lexmark F4270... • Answered on Mar 09, 2011
How do you fax on a lexmark printer?
my fax is not faxing nor my scanner, all I cna do is print.
9/23/2010 11:27:11 PM • Lexmark F4270... • Answered on Sep 23, 2010
Receiving faxes
Call the fax machine using a regular phone to see if it answers.
6/1/2010 8:13:43 PM • Lexmark F4270... • Answered on Jun 01, 2010
0answers
Error 1200
Error code: 1200
But it is the same as the Lexmark.
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Hope you get it to go.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
4/28/2010 5:45:05 PM • Lexmark F4270... • Answered on Apr 28, 2010
Error 1203
This is the inks
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
4/25/2010 6:30:21 PM • Lexmark F4270... • Answered on Apr 25, 2010
CHANGED CARTRIDGE
Yes ok try this
or
4/25/2010 6:18:58 PM • Lexmark F4270... • Answered on Apr 25, 2010
Lexmark F4270 Plain Paper Inkjet Fax Logo
Popular Tags
94 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Office Equipment & Supplies
Most Popular Question
fax not recive
  • Office Equipment & Supplies
