20 Most Recent Citizen DS777 2.2 in. Handheld Television Questions & Answers
No channels on either VHF
The news is not good, my friend.
The USA switched to digital broadcasts of TV signal around February 2009. Before that, all TV stations were transmitting analog signals. This TV has an analog tuner and is not able to receive digital broadcasts.
Unfortunately, this TV does not have any input jacks for coaxial cable, RCA cords, or even a plug for TV input. So you don't have any simple means to hook up to DVD players or videogames, or (most importantly) a digital-to-analog converter box. Basically, this TV has no value in the USA. If you take it to a country that still broadcasts NTSC analog signals over the air, though, you'll be in good shape. But if I'm on vacation in one of those places, the last thing I'm going to do is spend my time watching a teeny tiny television, you know?
3/12/2011 11:57:32 PM • Citizen DS777... • Answered on Mar 12, 2011
0answers
How can I get digital stations after February 2009?
go to walmart and get a digital box for basic television.
1/21/2009 6:06:49 PM • Citizen DS777... • Answered on Jan 21, 2009
0answers
Have an old Citizen ST760 handheld tv. What powers it. How do I get it going again?
Hello - See this YouTube video about the Citizen ST760 TV: https://www.youtube.com/watch?v=F5V_GGB3vqA The person talking on the video mentions batteries powering the TV. From the video, it looks like the opening to the battery compartment is on the right side (when looking at the TV screen.) Also, if you are in the USA, even with battery power, you will not be able to pick up any TV stations with the hand-held TV because it has analog TV reception and there are no TV stations broadcasting analog in the USA.
12/16/2017 6:49:31 PM • Citizen... • Answered on Dec 16, 2017
Just ordered Citizen Kane. Unable to stream it on TV. Get message " no HDCP" Now unable to stream at all. Please provide refund. TX
wrong site fixya doesnt sell or rent movies or streaming services --direct your request to the correct party
6/4/2017 12:04:29 AM • Citizen... • Answered on Jun 04, 2017
Where can I obtain a
Hi
Thanks for using FixYa. Please click on this link to buy the power supply cord which is a common one for LTD series:
Citizen TV power supply cord
Citizen TV power supply cord-2
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
9/16/2010 7:04:16 PM • Citizen... • Answered on Sep 16, 2010
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 2 hours ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 3 hours ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 5 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 9 hours ago
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered 9 hours ago
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 3 days ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 3 days ago
2answers
My Telefunken television model TLEDD-42FHDB remote made tv on/off switch flick and remote has stopped working now. Still doesn't work after replacing batteries.
Put the batteries back in and aim the front ot the remote at the front facing selfie camera on a smartphone. Press a button and you should see a flash. If no flash, the remote has failed. If there is a flash, the television IR module or main board has failed.
Telefunken Replacement TV Remote TLED-26FHDPA
Soundtech https://soundtech.co.za > telefunken-replacement-tv-rem... Telefunken replacement remote compatible with TV models: TLCD-29FHDP TLCD-32FHDA TLCD-32HDA TLCD-37FDHA TLCD-37FHDA TLCD-39FHDP TLCD-40FHDC TLED-26FHDPA ZAR 199.00 ..
4/15/2024 10:04:39 PM • Televison &... • Answered on Apr 15, 2024
Citizen DS777 2.2 in. Handheld Television Logo
Popular Tags
3 questions posted
Top Citizen Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Citizen Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Citizen Televison & Video
Most Popular Question
no channels either vhf
  • Televison & Video
