20 Most Recent Durabrand DWT2704 TV Questions & Answers
0answers
2answers
TV SCREEN STAYS BLACK!
Bad news. The tuner is bad. Instead of fixing the problem, you can hook up a vcr or dvd that has a tuner built in it. Hook it up to the video input and use the vcr or dvd to change channels. Or you can replace the tuner in the tv.
12/30/2016 7:23:34 AM • Durabrand... • Answered on Dec 30, 2016
2answers
V-chip reset
I cannot find any way to reset it. You might contact the manufacturer.
10/25/2014 2:57:28 AM • Durabrand... • Answered on Oct 25, 2014
Picture foldover
This is a vertical sweep output problem. Check and replace all the electrolytic capacitors in the vertical scan output section circuit. There will be 6 or 7 of it. Replace all of it at one time; it will be the best. Check it. For more information go to http://electronicshelponline.blogspot.com/
11/27/2013 11:57:26 AM • Durabrand... • Answered on Nov 27, 2013
Alba television code
0029,0022,0025. Try these codes. For more information
11/26/2013 3:53:52 PM • Durabrand... • Answered on Nov 26, 2013
I have a durabrand DBTV1024 and it is locked and i
Hello You can't unlock the V-Chip setting without entering into its service mode. This is actually a skilled work, and cannot be done without its remote control. If you have the remote control, entering into the s
This unit provided with the following SERVICE MODES so you can repair, examine and adjust easily. To enter the Service Mode, press both set key and remote control key for more than 1 second.Then set volume to minimum and press "0" digit on the remote control to unlock V-Chip and to set a new password. From this proceedings, you can know that, without its original remote control, the set cannot be unlocked. Try to get it from the nearest Duraband authorised service center or from any electronic spare part shops at your town. OK. ervice mode do the following>
10/19/2011 6:40:51 PM • Durabrand... • Answered on Oct 19, 2011
2answers
I am trying to program a remote control for
Hello
Four digit universal remote control codes for Duraband are:
0189 0135 0157
0153 0254 0458 0217
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
You can also use code remote finder search from the below link:
http://remotefinder.rca.com/default.aspx?site=rca
6/20/2011 5:15:20 AM • Durabrand... • Answered on Jun 20, 2011
I have a Durabrand DWT2704A
owners manual shows tou how to use front panel buttons to get to game mode if you dont have manual search internet download manual
3/30/2011 11:05:22 AM • Durabrand... • Answered on Mar 30, 2011
Remote is good but dont
Possible that there is fault in the remote that is not producing the same IR code to the receiver.
Please check the link below for tips to repair the remote.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
3/30/2011 11:01:24 AM • Durabrand... • Answered on Mar 30, 2011
2answers
TV won't turn on
The red light instead of green is an indication that theres a voltage missing or an improper voltage in the sweep or main power supplys. This should be handled by a trained service tech. Good Luck
3/28/2011 8:29:39 PM • Durabrand... • Answered on Mar 28, 2011
Not color
Hi mcm406,
If you already tried the system set-up to your menu (NTSC,PAL,SECAM,AUTO) but no luck and still the picture is black and white locate this parts on the board
This is 3.58Mhz crystal that responsible for producing color on your unit and other tv. Replaced it and your unit will back to normal again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
2/17/2011 3:50:32 AM • Durabrand... • Answered on Feb 17, 2011
Televison & Video Logo
69 questions posted
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Durabrand Televison & Video
Most Popular Question
lost remote control universal rca
  • Televison & Video
