20 Most Recent Craftsman StaplerBrad Nailer All Purpose EasyFire Forward Action Questions & Answers
How does the spring go on
if you open the top it has to go around a roller then attach to the pusher for the staples and then attach to the bottom up where the anchor point is.
4/29/2016 6:09:12 PM • Craftsman... • Answered on Apr 29, 2016
0answers
How to load it
Be the first to answer 3/2/2013 9:30:38 AM • Craftsman... • Posted on Mar 02, 2013Be the first to answer
0answers
Craftsman Air Compressor. I have to press the reset button on it. Can I stride wire it?
Question edited for clarity. Question moved from Misc to correct category. By 'stride wire', do you mean just short across the switch? Yes you can but really you need to fix the problem. You know these things can blow up and spray shrapnel 30 feet? Google Craftsman (model) parts You may have a short in the motor, in which case, shorting it out won't fix it. https://www.google.com/search?q=Craftsman+Air+Compressor.+I+have+to+press+the+reset+button+on+it
3/19/2023 3:29:17 AM • Craftsman Air... • Answered on Mar 19, 2023
2answers
Craftsman 6 gal air pan compressor
regulator is bad, or tank is not low pressure. you could return it for another one.
1/11/2023 8:50:53 PM • Craftsman Air... • Answered on Jan 11, 2023
6 hp 33 gallon tank Craftsman Air Compressor Model 919-167340 starts up for 1 or 2 seconds then trips the breaker
capacitor weak --motor drawing to many amps if using extension cord[s] not correct or to far from source and causing to much voltage drop -motor faling--compressor failing
7/18/2022 5:59:34 PM • Craftsman Air... • Answered on Jul 18, 2022
Craftsman Air Compressor keeps breaking pistons
That model number only shows in this post. I don't see how a compressor can be 'oil-less', the friction and pressure is enormous! https://www.google.com/search?q=6.5+HP+oil-less+60-GAL+MOTOR+%22K56A28B23%22 ..
2/17/2022 5:30:12 AM • Craftsman Air... • Answered on Feb 17, 2022
Brad Nailer won't fire a second brad. Brand new Craftsman compressor and nailer.
is the plunger sticking below the housing . if so push it back in with a screw driver
9/15/2021 12:11:18 AM • Craftsman Air... • Answered on Sep 15, 2021
Craftsman electric stapler 193.684231
Craftsman Electric Stapler Model #193.684231 aka 9-68423. (Came out in 1984) Can take up to 5 different size staples depending on your project. One feature is the "dual power" knob at the top which allows you to use "HI" or "Low" impact depending on the size staple used. Sorry about the blurry pictures, they are sharp on my computer. Try Googling the model number or looking on EBay. "No. 6" means "Heavy Duty Wide Crown .417 size."c8164434-0938-452f-9fd4-019a95e3826d.jpegstaple chart 2-4wxaff4qwcatgv1dszqr01mm-6-2_0.jpegstapler box -4wxaff4qwcatgv1dszqr01mm-6-3.jpeg
8/8/2021 6:26:21 AM • Craftsman Air... • Answered on Aug 08, 2021
I am looking for a copy of the owners manual for a craftsman air compressor model # 15362. It was not in the box when we purchased it.
https://manualzz.com/doc/50653102/craftsman-15362-owners-manual
3/6/2021 2:47:09 AM • Craftsman Air... • Answered on Mar 06, 2021
Craftsman brad nailer #351.181720, just stopped working, when safty is depressed just have air hissing
I have 351.181720 and the driver does not return. I've had this for years but it has not seen extremely hard use (probably less than 500 brads). Suggestions. [email protected]
1/22/2021 4:24:53 PM • Craftsman Air... • Answered on Jan 22, 2021
2answers
My Craftsman model 919.165230 air compressor trips the breaker after initial fill on restart. No air leakage from anywhere, if I empty tank and restart it works fine until it restarts.
Either the unloader valve on the pressure switch is bad or the extension cord is too long or the start capacitor is weak. When the tank is full, unplug and try to turn by hand a few turns. Air should come out the unloader valve drain fitting.
10/17/2020 9:01:14 PM • Craftsman Air... • Answered on Oct 17, 2020
Have craftsman air compressor runs but will not build pressure over 60 psi.
replace the faulty poppet valves in the compressor heads
1/25/2020 10:49:50 PM • Craftsman Air... • Answered on Jan 25, 2020
Motor wiring diagram craftsman compressor,919.167210
It should be pretty straightforward. What are you looking for ?
8/21/2019 5:20:14 PM • Craftsman Air... • Answered on Aug 21, 2019
2answers
I have a Craftsman model 919.166330 compressor. When I turn on the switch it runs for about 5 to 10 seconds and begins to slow down until it stops and hums.
Check the check valve, disconnect the tube between the pump and the tank and power it up and see if it still humms.
8/17/2019 7:15:31 PM • Craftsman Air... • Answered on Aug 17, 2019
Craftsman StaplerBrad Nailer All Purpose EasyFire Forward Action Logo
7 questions posted
Top Craftsman Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve Sweetleaf
Steve Sweetleaf
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Air Tools & Compressors
Most Popular Question
spring go
  • Air Tools & Compressors
