20 Most Recent
Grundig Satellit 800 AM/FM/SW Radio Questions & Answers
Grundig Satellit 500 loses reception
Hi
I had such a pb.
IC 103 CX7961 stopt to oscillate after ~30s ...
so the plls ref was out
I changed it without results
In fact the plastic trimmer C138 (4-20pf) was bad???( insulation?)
Since changing (10 years ago) : no problem
Good luck
Grundig Satellit 800 external antenna configurations
It looks like you have a real scientific project. It sounds fascinating and it seems to go well beyond the mere enjoyment of a simple Short Wave Radio. My suggestion: Put your hypotheses/questions to the test and you will form an informed opinion.
Satt 800 turns itself
R.L. Drake in Ohio can and does repair the Grundig 800 Millennium receiver.Contact John Kriner there, and advise him that I sent you.See info below.Joe RotelloKnoxville, TN
John Kriner - Lead Tech. Knows Grundig 800 inside and out
[email protected]
USA
R.L. Drake
230 Industrial Drive
Franklin, Ohio 45005-4496
Phone Numbers:
Office & sales phone: 937-746-4556
Technical support and repair parts phone: 937-746-6990
Grundig satellit 600 sound goes
If transistor T612 (BD533L) gets hotter than transistor T613(BD534L) even after the volume set to low/mid then this is an indication that it is already faulty even you've test it good using the multimeter. That is why the sound cut in and out. I would advice you to replace this part and its filter electrolytic capacitor C670 and C671 (220uf/25V).
Jdvillanueva
I just got grunding 800
This is valid for the Satellit 750 by Eton (current owner of Grundig)
When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range.
If it is used in North Ameraica, you are told not to go through procedure but do it any way.
SYSTEM Code setting
Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display
1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages.
2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America)
The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
