20 Most Recent
Grundig S350 AM/FM/SW Radio Questions & Answers
Pressing on power on/off would cause radio to come on for two seconds then off
I had similar problem with my S350. It was a component which had failed. I found a place that fixed it at a reasonable cost. It is ACT Electronics in Long Beach, CA. I don't have phone number but you can google it. It is run by a person from India. You send him the radio with a $30 check. He then assesses what is wrong, gives you a price to fix it, send him a check, then he fixes and sends you the radio. He did a fine job for me. Good luck!
Looking for inexpensive shortwave antenna for
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
Volume is low what could be the problem
The Power Supply voltage could be low..If you're using battery, replace them with new ones...otherwise check the power supply voltage as per specification of the model.
No power with ac or batteries
The radio can use D or AA batteries. There is a switch inside the battery compartment that selects the type of battery.
