20 Most Recent
Grundig GF70-600 TV Questions & Answers
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
My t.v has locked,how can i unlock?
If you wish to get some details; visit the site linked here.
Pull up older posts. Surf the site with patience.
Unlock procedure and to override the password lock to many popular brand TVs are given. Type in the
brand name and type of your device, in the search box [
at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
The TV monitor will not turn on even when the standby light is on.
The Button Assembly and IR Sensor needs to be changed. You can buy the parts from Ebay or Amazon and they are very easy to change and they cost no more than $20 That is the only thing I can think of other than the "transformer" which can be discharged if you unplug it for about 2 weeks. Good Luck.......
Grundig MFW 82-2501 no picture or sound
If you are getting the initial 'pang'(!!!???) noise, then it looks like a cold solder in the Horizonbtal Oscillator or Hor. Output stages.
The set is trying to power up, but the Horizontal Oscilator is not 'booting' up.
Since it is a new set, it must be under warranty....Get it checked by the company Technician.
Tv wont turn on
HiNormally Grundig tv sets when stop working the standby light is on. If it is so the power supply is faulty. You should check DC supply voltage in pin 6 of SMPS IC TDA4605.. If no voltage in this pin, check the limiting resistor connected in series. If these parts are OK, check the supply line rectifier diode for short.Sully
Grundig Televition (P37 830 Text) shows only one channel with an
hello, I had thesame problem. I tried everything, after 14 days, where was TV off a tried itagain...an the same problem: text " ATS... OK " So a tried hold 3seconds on Grundig driver button "OK" and then the started automatictunnig. After it - averything is function! :)
