20 Most Recent Fender American Precision Bass Questions & Answers
I have a fender precision bass serial number S885843. Any ideas how much this would be worth.
Your guitar was made at the Fuji-gen Plant (for Fender Japan), Japan between the Year(s): 1994 - 1995. Past that I can't seem to dig up information.
11/10/2014 12:58:47 PM • Fender American... • Answered on Nov 10, 2014
I have a Fender Precision Bass Guitar serial #503122. I'm curious about its age and value? It is in excellent condition.
this should be a 1960 bass and there was 18,000 of them made so it is not rare but the questions that must be asked to put it in the rare category is the bass 100% original = this means everything /pots /pickups /tuners /frets /finish and then the overall functioning of the parts EX. bent tuner that turns restricted causing tuning problems / pots that cut out / input jack that's screwed up / buzzing or severely worn frets /and or fret board wear /worn finish on the body/neck so you must go down the list of everything to come to the overall condition of your bass then you can grade it by it's condition and then see where the basses category is (PRISTINE) =never used still tags & case (fine) = slightly used tags & case (excellent)= used but no finish chips scratches everything original & working so you get the picture I am curious about this because most players know there basses very well so this tells me that you have acquired this bass recently or that it belonged to a family member? and was passed down to you post back with more info/pictures of the bass I'd like to see it Stephen
11/8/2014 1:50:27 PM • Fender American... • Answered on Nov 08, 2014
How do install a pickups on a Fender Precision Bass with the serial number of MN515087
Wiring diagrams are in the Support ssection on the Fender site.
11/2/2014 4:06:57 PM • Fender American... • Answered on Nov 02, 2014
Fender serial number look up
The "S" means it was manufactured in the 1970's. The "8" means this was made in 1978.This serial number would suggest this is an 1978 American P Bass. Depending on the condition, you should be expecting to get in between $1200 and $2000. But always remember, a guitar is only worth what people are willing to pay.
9/4/2014 9:22:33 PM • Fender American... • Answered on Sep 04, 2014
What year was my fender precision bass made
s=seventy 8=year s+8=78-95779 is to #in the production yours was the 95779 one made
8/27/2014 11:28:01 AM • Fender American... • Answered on Aug 27, 2014
Fender serial number look up G14449
something is wrong here the serial number is missing either a # or letter the G denotes a Japanese bass and the year would be 87-88 the prefix GO and 5 #'s wood mean it is a walnut p bass special from 1982 ?
8/26/2014 8:04:49 AM • Fender American... • Answered on Aug 26, 2014
Manufacture date of fender serial number lookup s758046
Your guitar was made at the Fuji-gen Plant (for Fender Japan), Japan in the Year(s): 1994 - 1995
7/26/2014 12:02:13 PM • Fender American... • Answered on Jul 26, 2014
2answers
I need the owners manual for a Fender Precision
Try going to a music store, or you can go to the manufactures website and download or order one.
6/16/2011 8:36:30 AM • Fender American... • Answered on Jun 16, 2011
Fender Squier Stratocaster serial number CY01084527. What year was it made and the value please?
Your squier guitar is from 2001 Says the last link. For value, check eBay sold listings.
Serial Number Lookup
Fender Guitars https://serialnumberlookup.fender.com Fender is proud to now offer self-service serial number search function. Feel free to bookmark the link for future reference, and please be aware that not every ...
Serial Number Tracking
Squier Wiki http://www.squierwiki.com > Serial-Number-Tracking The serial number is printed on a sticker located on the back of the neck, close to where the neck attaches to the body. Because the number was placed on a ...
Squier Serial Number Lookup
Authority Guitar https://authorityguitar.com > squier-serial-number-loo... Mar 8, 2023 - It's simple enough with our squier serial number Checker. Type your serial numbers into the decoder below and you'll get all the information ...
Squier Serial Check
Squier Serial Check http://guitarcheck.info Squier Guitar Check (1982 - 2011). Serial number. Serial Number should be 6-12 characters. Serial Number is required. Country of origin. Select Country, CHINA ... ..
12/30/2023 6:14:49 AM • Fender Music • Answered on Dec 30, 2023
2answers
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM • Fender Music • Answered on Dec 15, 2023
Fender G-DEC Amp. How do I reset my Fender g deck amp to factory settings please?
Question edited for clarity and correct name of Amp. https://www.google.com/search?q=Fender+G-DEC+reset
Advanced Owner's Manual - fmicassets.com
fmicassets.com https://www.fmicassets.com > Damroot > Original PDF Preset Restore will NOT restore any media (band tracks) if they have been deleted from the G-DEC 3 hard drive (HD), which can only be done using the Fender FUSE .. ..
5/7/2023 2:28:42 AM • Fender Music • Answered on May 07, 2023
2answers
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience. I recommend the Fender single button footswitch for this use - Type: Footswitch
  • Number of Footswitch Buttons: 1
  • Manufacturer Part Number: 0994052000
  • It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
  • 11/22/2022 1:29:51 PM • Fender Music • Answered on Nov 22, 2022
    Guitar amp input not working
    Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
    4/17/2022 3:41:52 PM • Fender Music • Answered on Apr 17, 2022
    Fender bxr100 bass amp: while playing volume decreased to zero over a few seconds then smoke. Ideas? Rectifier?
    I would suspect that the issue is filter capacitors that have gone bad.. The amp is of the mid 90's era. You should be able to spot the failed parts if you have the proper knowledge about what to look for. Here is the schematic fender_bxr-100_sch.pdf_1.png (1529×990) (elektrotanya.com)
    7/20/2021 2:09:26 AM • Fender Music • Answered on Jul 20, 2021
    Fender banjo 130300028 Year type & value
    https://support.fender.com/hc/en-us/articles/212774866-How-can-I-find-out-when-my-old-Fender-banjo-was-manufactured- https://www.banjohangout.org/group/fenderbanjoowners/blog/6069
    Product Dating - Fender
    support.fender.com > en-us > 202726846-Product-Dating
    Product Dating. Find out exactly when your instrument or ... How can I find out when my old Fender® banjo was manufactured? How can I find out how old my ...
    Fender Banjo Serial Numbers Kd - engswift's diary
    engswift.hatenablog.com > entry > 2019/12/24
    Dec 24, 2019 - Look on the headstock of the guitar to find the serial number for a Fender Stratocaster. It may be located on the front or the back. The serial ...
    Fender Instruments Serial Number Dating Guide ' The Music ...
    www.themusiczoo.com > blogs > news > fender-instru...
    May 18, 2010 - For years, serial numbers have been used in various locations on Fender instruments, such as the top of the neck plate, the front or back of the ...
    Fender Banjo Serial Numbers? - narkive
    alt.banjo.narkive.com > awlepEsk > fender-banjo-serial...
    heads with a "soundhole" in it!) Anybody know if and where there might be a list of Fender banjo serial numbers that can be used to date this critter? Fender says
    12/19/2020 8:29:18 PM • Fender Music • Answered on Dec 19, 2020
    I have the fender passport 500 and use it as a karaoke system. Its been working fine but all the sudden now we have to turn the volume almost full blast to make the music loud to sing with. Before we always had it half way. Any help would be appreciated.
    This could be the speakers that have become damaged or the final audio transistors. It would require you to have a way to test them to be sure which it is. The speakers can be tested with an OHM meter to see if the voice coil is bad. To test the amplifier you would need more specialized equipment like a scope, audio watt meter or component tester, To use the component tester or to perform service on the unit you will need to be able to solder.
    11/7/2020 3:04:29 PM • Fender Music • Answered on Nov 07, 2020
    Fender American Precision Bass Logo
    9 questions posted
    Top Fender Music Experts
    Sean Wright
    Sean Wright
    Virgil Watts
    Are you a Fender Music Expert? Answer questions, earn points and help others
    View Most Popular
    Fender Music
    • Fender Music
    Most Popular Question
    • Music
