20 Most Recent
Symphonic ST427FF TV Questions & Answers
Symphonic WF27F4 (an old tv??) How to restore the
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
12/3/2011 6:36:51 AM •
Symphonic...
Answered
on Dec 03, 2011
What channel do you run
If you have RCA connections (AV 1 or AV 2) will work. You may use the RF connection (Cable TV Connection). Be sure in this case you tune to channel 3 or sometimes channel four. Your TV will have an internal switch that provide an acceptance to either channel. If you use the RCA connections, you will have use the input button on your remote. Thanks for asking and show all hands of support!
6/15/2011 3:22:46 AM •
Symphonic...
Answered
on Jun 15, 2011
My remote stopped working. I replaced batteries,
it could be sensor on tv
try holding remote in front of a video recorder and if you push button on remote and view through video recorder you should be able to see the light blinking coming out of remote - if you see the light coming out of remote and it is still not working then the tvs sensor went bad
besides trying to unplug tv for a few minutes there is no reset for this issue
3/21/2011 3:38:13 PM •
Symphonic...
Answered
on Mar 21, 2011
Turn on and it goes off.
Bad Crt Tv better buy new one most of the times its bad soldering in the old tvs or blown caps in your case it can be Fbt transistor or alot other things the first step is to open it up and look :D
9/22/2010 6:24:42 PM •
Symphonic...
Answered
on Sep 22, 2010
