20 Most Recent
Canon EOS 60D Digital Camera Questions & Answers
Canon 60d built in flash will not pop up.
The external flash mount (hot shoe) has a small sliver of metal which when the external flash gun is slid on pushes it down to tell the body to not use the pop-up flash and some times the sliver doesn't return fully up to contact the underside of the hotshoe
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
72 dpi instead of 300dpi
You do this in your editor. In photoshop you go Image -> Image Size and you'll see resolution set at 300 as default just change the 300 to 72.
How do I fix the flash?
You don't give any details, error message? if it is the same has the 550d, hold the camera has if you're taking a photo. look at the flash shoe, on the right hand side under the grouve where the extrenal flash slides in there is a tiny button switch if that is stuck the builtin flash will not work
How to get flash on canon 60D to pop up
Go into the menu and ensure it is 'enabled' to fire automatically. Or press the lightning arrow button on the side or in a darkish room set the aperture to something like f16 and press the shutter button.
Flash won't pop up canon 60d
check whether the flash unit is struck, loosen with a film piece, just insert through the groove of the flash unit, this will help to loose the sticky lock from in side.
if the popup relay circuit pbm you must open it check the circuit , the electromagnetic relay an related mechanism. beware of shock hazard from the capacitor.
Flash won't open
totally open the camera, remove front portion, at the right side you can find the popup drive motor and related gears, try to loosen the gears struck if any, the power on , put full auto, push snap key, check whether flash popup, if not check the motor, first disconnect it, give a 3 volt at the motor terminal if rotating there may be problem in the circuitry, use digital multi tester to measure the voltages,
60d flash pop up
Mode dial is set to an auto mode or the setting is set for flash photography. Change that and the built-in flash unit won't pop-up every time you press the shutter button.
Canon 60d flash won't pop up
It is a problem with them that if you fit a flash to the hotshoe that after a while the tabs under the hotshoe rails don't pop back up so you have to get a micro bladed screwdriver and GENTLY prize them up until they contact the rail then try the popup button again
My camera screen went black and I have no functions. I open up the compartment door to remove the card and it beeps like it is processing even though camera is turned off and no red lights are on. I
I cannot give you a straight answer. It all depends. You cannot tell for sure what has happened and in which phase of the file writing things happened to go wrong. If it's just stuck there, it might be possible that it already finished writing but stays in a loop. What it does by writing is to first look in the FAT-table on the disc wich places can be used to write data. If it found area's, it starts writing and at the end it will update that same FAT-table that the space it occupies cannot be used anymore. If you stop in that proces, chances are that the FAT-table gets corrupted and the card will give an error when you try to read. No big problem as every disc tool can rebuild a FAT-table from the data thats been stored on the disc. If there was a more severe error that started overwriting data on the disc in a unpredictable manner, you're doomed. Either way, no other option than to remove the battery, remove the card an see what's the damage and try to recover the images......
Afterwards, just format the card and test it. Card may still work after that.
