20 Most Recent MSI Wind Top AE2400057US PC Desktop Questions & Answers
The wait is usually due to shipping times, back log, and the time it takes to order the part. This is pretty standard.
MSI Wind Top... | Answered on Nov 06, 2013
Most likely thinks your version is a clone. I kept having this happen to me with a new computer I bought with Vista on it. After a week I got fed up of it and demanded my money back at the store where I bought it.
MSI Top... | Answered on Mar 08, 2016
there must be a hardware fault it could be that your system won't support your hardware configuration or it could be the heating problem... you better take your PC to an computer engineer
MSI Top... | Answered on Sep 06, 2014
Open run by pressing window and 'r' key together and type %tenp%
then hit enter, delete everything after selecting all, this is all temp data,
clear all your browser history,
AND TRY again please.
MSI Top... | Answered on May 13, 2014
Try installing the game in safe mode.
MSI Top... | Answered on Dec 09, 2013
bluescreen can be caused by a number of things
a bad driver loose or faulty lead or not having enough ram
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you dont want to install more ram uninstall some unnecessary programs
a bad or faulty motherboard lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
hope it helps
MSI Top... | Answered on May 19, 2012
open your keyboard and cleans the key pad keys . If you using your keyboard more then 2 years its better to change it
MSI Computers &... | Answered on Jan 07, 2020
i want webcam driver for windows7...?
MSI Computers &... | Answered on Sep 12, 2019
I suppose, you won't be able to fix it that easily. Something is wrong with the keyboard and most likely you'll have to replace it. But I'd say that it is pointless. I mean, the laptop is a bit outdated so why not to get something better? There are so many options out there. If you need a laptop for doing job, here you can take a look at these laptops for quickbooks and daily accounting which can handle basically, any taks besides resource intensive ones like gaming, 3d rendering, etc.
MSI Computers &... | Answered on Aug 28, 2019
Although I've got a different type of MSI but I have where the "official guys" say there should be: at the back of it, maybe you need to remove the battery and look there under "S/N: xxxxxxxx"
MSI Computers &... | Answered on May 11, 2019
that 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
MSI Computers &... | Answered on Apr 12, 2019
Well, you could uninstall anything related to the sound device. If you can, I suggest using the sound driver provided by the manufacturer. Let me know how it went, thanks.
MSI Computers &... | Answered on Jan 26, 2019
MSI Wind Top AE2400057US PC Desktop Logo
1 questions posted
Top MSI Computers & Internet Experts
Ekse
Thomas F. Schneider
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Top MSI
  • Top MSI
Most Popular Question
replace ae2400 057us motherboard
  • Computers & Internet
