20 Most Recent Vivitar DVR 508HD Digital Video Recorder Questions & Answers
How to reset my vivitar DVR 508HD
What exactly needs to be reset ? Is this information not in the camcorder manual ?
6/6/2016 10:30:34 AM • Vivitar DVR... • Answered on Jun 06, 2016
Vivitar 508nhd wont work when SD card put in
Are you sure you have an SD card (2GB or smaller)? The 508 won't work with higher-capacity SDHC cards.
1/29/2013 4:25:16 PM • Vivitar DVR... • Answered on Jan 29, 2013
How do i know it charging
The DVR 508HD is a video camera, not a battery charger. As such it doesn't charge batteries at all. It uses three standard AAA batteries, either disposables or rechargeables. If you use rechargeables, they must be recharged outside the camera using a separate charger.
11/17/2012 12:18:44 AM • Vivitar DVR... • Answered on Nov 17, 2012
Need a good cheap camcorder to record basetball games. Found Vivitar DVR508 HD but can't find how much time it would record. Can you tell me please??
Yes, the camcorder will record for two hours. The two biggest limiting factors are the memory cards and the batteries. Depending on the resolution, you may need a second card. You may also need a fresh set of batteries.I don't know how a "basetball" game is organized, but if you're taping a baseball game, you should be able to swap memory cards and/or batteries between innings. If you're taping a basketball game, you should be able to do the same at halftime.
2/1/2012 9:46:50 PM • Vivitar DVR... • Answered on Feb 01, 2012
0answers
Sd card is locked ,tried two different cards. how
There is a small slider on the thin side of the card for lock/unlocking.If you have tried two new cards then the camera probably has a fault with it's detection sensor.That's a job for a camera tech.
1/6/2012 1:00:41 AM • Vivitar DVR... • Answered on Jan 06, 2012
Camcorder shuts off after 3 seconds and says card error
Try formatting your card in the camera.Note: formatting will erase all the files.
1/6/2012 12:48:41 AM • Vivitar DVR... • Answered on Jan 06, 2012
Screens is reading card is locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
12/14/2011 10:33:05 PM • Vivitar DVR... • Answered on Dec 14, 2011
How much time do you
About an hour with AAA and around 2 1/2 for rechargeable.
3/26/2011 2:34:36 PM • Vivitar DVR... • Answered on Mar 26, 2011
Received DVR528 camcorder, CD included contains
It's DVR, not DVD.
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/418/DVR_528_Camera_Manual.pdf
3/10/2011 11:54:36 PM • Vivitar DVR... • Answered on Mar 10, 2011
Vivitar DVR 508HD Digital Video Recorder Logo
38 questions posted
Top Vivitar Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
View Most Popular
DVR Vivitar
  • DVR Vivitar
Most Popular Question
vivitar 508nhd wont work when sd card
  • Video Cameras
