20 Most Recent
Kodak C195 Digital Camera Questions & Answers
C-195 won't upload to my computer. Installed app which now says I have an invalid extension. Have no idea what that is or how to fix it.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Kodak C195
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
How to download
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Kodak Easyshare c195
Press the MENU button, choose the Settings tab (three horizontal sliders), then select the sixth item from the bottom of the submenu.
I would like to be able to take a good picture of a full moon on a clear night.
You're going to face two separate problems here. One, the moon occupies a rather small portion of the night sky. Even fully zoomed in, the moon is going to be not much more than a bright spot in the sky.Two, the camera is designed to assume that almost every scene is an average brightness. Given how much of the scene is a black sky, the camera will attempt to render the sky as average (what photographers call a "medium gray"). This will result in a picture with a gray sky and a featureless white blob for the moon.If you think about it, the full moon is nothing more than a really big rock under a midday sun. Thus what you want is the same exposure as when taking a picture on a clear sunny day. Unfortunately the camera is going to be fooled by all that dark sky and try to compensate for it. What you really need is to be able to bypass the camera's light meter and set the proper exposure yourself. The C195, unlike more sophisticated cameras, doesn't allow you to do so. Sorry, but that's just the way it is.
Water on inside of c195 lens
Hello Mike, This is best done by a qualified camera shop, too many things to go wrong when working with the lens unit, even a small scratch can be very costly as these lens are coated and if not handled correctly can be ruined.Best Regards, Russell
Wont upload to my mac book
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
