20 Most Recent Compaq Presario 5280 PC Desktop Questions & Answers
Erase hard drive
I use this free utility to wipe computers before I dispose of them: http://www.dban.org/ I hope this helps.
7/16/2016 4:40:22 PM • Compaq Presario... • Answered on Jul 16, 2016
Compaq presario desktop SR1000 wiring diagram
You can download upgrading and servicing guide from COMPAQ PRESARIO SR1000 - DESKTOP PC MANUAL Pdf Download ' ManualsLib
4/23/2024 9:24:04 PM • Compaq Computers... • Answered 8 hours ago
2answers
Compaq evo n115 boot from usb
Is is probably too old to take Win 10. Also, USB support normally starts once Windows is loaded. During Boot up, it looking for a hard drive or Bootable CD Media. By default, the notebook can start only from a bootable hard drive or bootable drive medium in the notebook. https://www.google.com/search?q=Compaq+evo+n115+boot+from+usb It is 21 years old!!
QuickSpecs
NTS Computers Technology BV https://www.nts.nl > pdf > Compaq_EVO_N115 Compaq Evo Notebook N115. DA-11059. World Wide - Version 7 - August 12, 2002. 1. Overview. What's New. • AMD Athlon™ 4 and Duron™ processors with PowerNow ... 15 pages..
4/20/2024 2:28:56 PM • Compaq Computers... • Answered 3 days ago
Where can I find the latest BIOS and drivers for a Compaq Evo N610c laptop
It is 22 years old and there is not support for the virus magnet that is called Windows XP!
COMPAQ N610C QUICKSPECS Pdf Download ' ManualsLib
ManualsLib https://www.manualslib.com > manual > Compaq-N610c View and Download Compaq N610c quickspecs online. Compaq OWNERS MANUAL Notebook N610c. N610c laptop pdf manual download. Also for: Evo n610c. Drivers https://www.google.com/search?q=compaq+evo+n610c+laptop+drivers+download 'Latest' BIOS Upgrade is 2004 (2 year support) https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade+download https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade ..
4/18/2024 2:40:38 PM • Compaq Computers... • Answered on Apr 18, 2024
2answers
My compaq 610 windows logo is stuck during booting and even if I want to format it. Any help?
Windows 7 should be the OS. If you go to safe mode, it should complete booting and then you can list the errors but I suspect there is a driver error. Maybe the wrong version in there.
4/17/2024 1:03:41 AM • Compaq Computers... • Answered on Apr 17, 2024
I was just donated a Compaq c769 us I wanted to know in it's day was it a good unit ad is it relable 2008 model. It's in pristine condition from what I see ordered power chord on line will check soft ware and functionality ounce it becomes available.
Hopefully it will still work with a new battery and power supply to charge it. They were quite reasonable back in 2008. Win7 software (no longer supported) and fairly fast.
4/16/2024 8:19:02 PM • Compaq Computers... • Answered on Apr 16, 2024
4answers
How to download whatsapp on laptop
As WhatsApp was originally designed for phones the process adn solution are not as straight forward as you might think, See the sites listed below: Download WhatsApp For Laptop PC Windows 8 1 8 7 Install Whatsapp http://fasttechbuzz.com/download-whatsapp-windows-8-1-7-pc-laptop-free/ download-whatsapp-for-windows-laptop-160x120.jpg If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
1/28/2024 5:02:48 AM • Compaq Computers... • Answered on Jan 28, 2024
Hp compac nx6110 drivelock HDD BAY password, reset
Hey readersFollow these steps to troubleshoot that issue. Warning -Please don't your that tip for illegal work . Its only for personal and training purpose. You can also follow my tip
12/16/2023 6:38:16 AM • Compaq Computers... • Answered on Dec 16, 2023
How do i verify my number on badoo
9/13/2023 6:38:32 AM • Compaq Computers... • Answered on Sep 13, 2023
10answers
Best antivirus for window-7 ultimate 64-bit
am sure it is eset nod http://www.eset.com/download
6/12/2023 9:49:33 AM • Compaq Computers... • Answered on Jun 12, 2023
2answers
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
11/22/2022 4:45:51 PM • Compaq Computers... • Answered on Nov 22, 2022
Compaq presario c500 dos not detect ssd hard drive
Computer is probably too old to recognize an SSD. You may be able to find a firmware upgrade. Did you boot into the BIOS and try and find the SSD? https://www.google.com/search?q=Compaq+presario+c500+dos+not+detect+ssd+hard+drive ..
10/26/2022 12:48:29 AM • Compaq Computers... • Answered on Oct 26, 2022
My Compaq presario sr1313cl desktop pc, is not working a Capacitor is bad!
Replace the capacitor.
9/25/2022 4:31:03 PM • Compaq Computers... • Answered on Sep 25, 2022
3answers
I have a compaq cq5110y computer. When I push the power button nothing happens. It doesn't turn on, no fan or lights come on either. The only light that is on is on the back of the computer and it's
It might be a connector cable between the mother board and the power supply has worked loose when the machine was moved. That blinking light appears to be on the power supply. While there might be other causes, I suspect the power supply needs to be replaced. You could take up considerable time and try to reseat everything and check all the connections and even put new thermal paste between the CPU and heatsink, but in the end, I suspect putting in a new (or used of the same type) power supply will be the fix. If the power supply has failed before damaging anything, that at least would be good news.
8/26/2022 8:55:03 AM • Compaq Computers... • Answered on Aug 26, 2022
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch. XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020??? gee google that. 2001 to 2007 was XP rein , vista 2007 I bet there are 1millons of web site still with XP usage .(old topics) google them. but Microsoft purged theirs. it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen.. worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC) to use any relic PCs run LINUX> not XP
7/27/2022 4:10:03 PM • Compaq Computers... • Answered on Jul 27, 2022
My Compaq Presario Laptop won't open certain sites because they are not "secure" eg. Quora, BBC Weather, sundry health sites, etc.
Question edited for clarity, and Maker name. Question moved from BBC Computers. BBC Weather and Quora and both secure and have an http*S* security certificate. My guess is that you have a third party security app, or worse, two of them, not understanding status or fighting with each other.
7/12/2022 10:03:51 PM • Compaq Computers... • Answered on Jul 12, 2022
1998 Compaq Prosignia 144 Laptop parts
It is an obsolete dinosaur from April 1999. Put it back in the dumpster where you found it. It was in there for a reason :>D https://www.google.com/search?q=compaq+prosignia+144+parts+diagram ..
6/21/2022 7:38:08 PM • Compaq Computers... • Answered on Jun 21, 2022
Download free microsoft word
2/7/2022 9:16:15 PM • Compaq Computers... • Answered on Feb 07, 2022
How to fix 1780 disk 0 failure
bad hdd.
  1. buy a new hdd.
  2. buy upgrade to SSD
  3. buy it in a PC store like Bestbuy
  4. buy it at ebay , amazon or 1000s of online stores (googled)
  5. the reload the OS.
  6. or have a shop fix your PC and avoid all this , work.
2/7/2022 9:16:12 PM • Compaq Computers... • Answered on Feb 07, 2022
Help Please. Need to download the following drivers for my Compaq Presario v2000, P/N ez617ua#aba laptop. 1.Network Controller 2. PCI Modem 3. SM Bus Controller 5. Video Controller (VGA Compatible).
HP.com 2005 RELIC PC. HP owns and sold Compaq 2002 to 2013 (now ended) HP also now ended all support on some compaq's (oldest) XP THE VIRUS MAGNET ENDED 2014 SO WHY USE XP?????? HP HAS MANUAL http://h10032.www1.hp.com/ctg/Manual/c00501998.pdf READ THIS https://h30434.www3.hp.com/t5/Notebook-Video-Display-and-Touch/Compaq-presario-v2000-display-driver/td-p/6407791 DRIVERS https://h30434.www3.hp.com:443/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=Presario+v2000+DRIVERS ask hp.com for drivers if you google them,end less virus infections await avoid XP forever and win.
2/7/2022 2:37:14 PM • Compaq Computers... • Answered on Feb 07, 2022
Compaq Presario 5280 PC Desktop Logo
1 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
erase hard drive
  • Computers & Internet
