20 Most Recent
Oritron DVD4119 Questions & Answers
I have an Oritron dvd4119
http://www.urcsupport.com/html.php?page_id=292 You can input the different components and get additional codes there. Try 20651 first.
Setup Instructions
- Turn on your device (i.e. TV).
- PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
- PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
- ENTER the 5 digit code for your brand from the list above.
- You should receive 2 quick flashes on the LED for the selected device after entering your code.
- PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Please leave feedback!
Region code
when "no disc" screen is showing,
press 16719 (slowly) to get secret menu.
then change to region 0 to include all regions or 2 for region 2.
Will not read.
almost any electronic store can help you but i would try factory customer support first it probably cheaper to just buy a knew player
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
10/5/2017 12:26:12 AM •
Oritron...
Answered
on Oct 05, 2017
Someone please give me the codes for oritron dvd player. I lost the codes for thisvibe axcess 5 in 1 remote. Please help
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
10/21/2016 2:50:49 AM •
Oritron...
Answered
on Oct 21, 2016
