20 Most Recent Oritron DVD200 Questions & Answers
Lost our owners manual for our Oritron DVD 200.
check this out http://tv.manualsonline.com/manuals/mfg/oritron/dvd200.html, hope this info help you resolve your problem.
6/7/2011 10:00:31 PM • Oritron DVD200 • Answered on Jun 07, 2011
tip
Oritron DVD-200 Region Free Fix
Oritron Diamond DVD-200 DVD Player Region Free Fix
Would you like to unlock your Oritron Diamond DVD-200 DVD Player to Region Free?
Follow these steps to unlock your Oritron Diamond DVD-200 DVD Player:
  1. Press the Menu button on your remote control.
  2. Press the 9 button on your remote control.
  3. Press the Open/Close button on your remote control, (note the tray will not open).
  4. Press the 5 button on your remote control.
  5. Press the Mute button on your remote control when presented with the region selection page.
  6. Press the OK button on your remote control when presented with the region selection page.
  7. Press the Exit button on your remote control when presented with the region selection page.
  8. The word ALL will appear on the screen and your player will now play discs from any region.
Your Oritron Diamond DVD-200 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 • Oritron DVD200
I HAVE A ORITRON5 DISC DVD AND CD AND MP3 RECEIVER
sorry machine i said it ,,,wont buy another one oritron
2/6/2008 12:35:48 PM • Oritron DVD200 • Answered on Feb 06, 2008
0answers
Oritron DAV 3101
Be the first to answer 10/26/2007 11:19:08 PM • Oritron DVD200 • Posted on Oct 26, 2007Be the first to answer
Oritron DVD3116 DVD player. I need a manual for it?
It is a virtually unknown make, and there is no manual online. https://www.google.com/search?q=Oritron+DVD+3116+manual There is a workaround though. Use a Smartphone with the Google Translate app on it and use the camera feature to translate what you are seeing in real time. https://www.google.com/search?q=google+translate+app+camera+function https://www.google.com/search?q=google+translate+app+camera+function ..
6/23/2023 6:51:01 PM • Oritron... • Answered on Jun 23, 2023
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i) NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines. You might try disconnecting all power from the system. unplug it. disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
10/5/2017 12:26:12 AM • Oritron... • Answered on Oct 05, 2017
MANUEL INSTRUCTIONS POUR CINEMA MAISON ORITRON DAV 3102 EN FRANCAIS S.V.P.
If you wish to get some details; visit the site linked here.
2/10/2017 1:34:56 AM • Oritron... • Answered on Feb 10, 2017
Someone please give me the codes for oritron dvd player. I lost the codes for thisvibe axcess 5 in 1 remote. Please help
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
10/21/2016 2:50:49 AM • Oritron... • Answered on Oct 21, 2016
Oritron dvd player door keeps opening
Some type of light source mimics remote?
8/20/2013 11:37:49 PM • Oritron... • Answered on Aug 20, 2013
Oritron amplifier has no input ?
Check its powersupply regulator circuit, and main amplifier circuit for any shorted component/s. Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help
5/20/2012 1:06:31 AM • Oritron... • Answered on May 20, 2012
A DVD is stuck in
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
  1. unplug the device (dont wanna get electrocuted)
  2. remove the screws to the back and under the player
  3. lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
  4. you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
  5. remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
4/5/2011 1:06:24 AM • Oritron... • Answered on Apr 05, 2011
It keeps cutting off
If you are using the power cord, your power supply is failing or overheating. If it is on battery, replace or fully charge the battery.
8/9/2010 10:21:46 PM • Oritron... • Answered on Aug 09, 2010
I have been given a Oritron DVD720 player and the
More than likely you can.
I would suggest looking it up at www.newremotecontrol.com
just look it up by brand and model number and they should have a corresponding remote part number which they sell.
7/28/2009 11:33:23 PM • Oritron... • Answered on Jul 28, 2009
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 6 hours ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 7 hours ago
2answers
My Telefunken television model TLEDD-42FHDB remote made tv on/off switch flick and remote has stopped working now. Still doesn't work after replacing batteries.
Put the batteries back in and aim the front ot the remote at the front facing selfie camera on a smartphone. Press a button and you should see a flash. If no flash, the remote has failed. If there is a flash, the television IR module or main board has failed.
Telefunken Replacement TV Remote TLED-26FHDPA
Soundtech https://soundtech.co.za > telefunken-replacement-tv-rem... Telefunken replacement remote compatible with TV models: TLCD-29FHDP TLCD-32FHDA TLCD-32HDA TLCD-37FDHA TLCD-37FHDA TLCD-39FHDP TLCD-40FHDC TLED-26FHDPA ZAR 199.00 ..
4/15/2024 10:04:39 PM • Televison &... • Answered Yesterday
Oritron DVD200 Logo
8 questions posted
Top Oritron Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Oritron Televison & Video
Most Popular Question
oritron5 disc dvd cd mp3 receiver
  • Televison & Video
