Ford Fairlane 1992 start up problem
hello maurice,sounds like you have a few possible problems on hand there.1st off,if cars fail to start,esp on a wet or damp days,nearly always the air density has changed to such a state,that atomisation is not taking place [fuel is not vaporizing in to the combustion chambers]and creates a 'heavy' state of which the fuel cannot burn properly [ignite] you need to be certain that your car is in fairly good mechanical condition,and all the relevant criteria[ignition system,plugs,coils,sensors,air filter/fuel filters are in a serviceable condition,merely guessing that your fuel pump is useless,is not the correct way to go with your particular problems here,as you can get the line pressure checked without dis-assembly,establishing the overhaul condition of the working pressure of the pump,as 'suspicion's' of this that and the other,will certainly wipe out your bank account,and may not solve your particular problem.cheers,and hope that this has helped.
