20 Most Recent
Minolta Di151 All-In-One Laser Printer Questions & Answers
Show C 13
C1300
Polygon Motor malfunction
-Startup failure
- Lock signal fault: Unstable after the first Lock signal has been detected
- Lock signal fault: Lock signal out-of-timing
The printer is giving me a code J-2
Isn't that a paper jam? If so you may have a piece of paper somewhere lodged in your printer, Check all moving parts to see if you see anything.
Laser printers are more sensitive than Bubble Jet.
What do I use for a toner
you will need the Minolta 4153-102 Black Toner Cartridge.
Can be found at most office supply stores.
Minolta Di151 copier. J2
Check whether any piece of paper struck in the paper sensor. Remove the same will resolve your problem.
Thank you for using Fixya.
