20 Most Recent Microsoft Outlook 2003 for PC Questions & Answers
2answers
My outlook 2007 has reached
As archives are in a separate PST than your Mailbox (Inbox, Calendar, Sent Items, Deleted Items, Contacts etc), you may need to focus on this section to be reduced. Biggest culprit for used space is deleted Items. Empty this by right clicking and select Empty deleted items folder. Once empty, it is a good idea to archive messages in your Sent Items folder to another PST or Personal Folder. Once you have done these steps, right click your Mailbox Account (icon of House with a minus sign beside it - under All Mail items), and select Properties for "Your Mailbox Name" Click Advanced button, and click Compact now. This will compress your PST file, and remove any space once occupied by any moved or deleted messages. This process could take a while, and should not be interrupted.
1/31/2024 3:32:35 AM • Microsoft... • Answered on Jan 31, 2024
3answers
Outlook cannot open with error message, the set of
EdbMails Outlook PST repair tool extracts the corrupt, damaged, healthy PST files. The software deeply scans the entire PST file and recovers its data items with high precision. It directly migrates the recovered PST to Live Exchange/ Office 365 server. To know more : https://www.edbmails.com/pages/outlook-pst-recovery.html#
1/30/2024 4:58:55 AM • Microsoft... • Answered on Jan 30, 2024
Delete from Outlook subject line
hi,
create folder and copy all the messages in.
Now right-click the folder containing the messages and click on delete..
Please let me know when your successful or not.
Cheers
6/25/2023 4:10:06 AM • Microsoft... • Answered on Jun 25, 2023
2answers
OUTLOOK.PST REACHED MAX SIZE, BUT CANNOT DELETE OR
Try to "purge deleted items".
Then, within Outlook, click File.
Click Folders.
Click Compact All Folders.
Try again to delete/move.
6/24/2023 4:57:33 AM • Microsoft... • Answered on Jun 24, 2023
3answers
Outlook does not respond when started
You will need to go to the Microsoft solution center to follow the fix for this.
this may be due to the rules setup for Outlook after an upgrade.
Some feature in Outlook may be disabled.
check this knowledge base article page to see if these apply to your issue.
http://support.microsoft.com/kb/886616
6/30/2022 3:57:29 PM • Microsoft... • Answered on Jun 30, 2022
2answers
Restoring outlook data files
Try File --> Import and Export --> importing from anothe file or program --> Personal Folder File (.PST)
7/6/2021 4:29:30 PM • Microsoft... • Answered on Jul 06, 2021
6answers
Outlook 2003 backup
file -> open -> outlook data file direct it to the location of the file.
7/6/2021 4:23:56 PM • Microsoft... • Answered on Jul 06, 2021
tip
How to repair Outlook folders using the Inbox Repair Tool
Inbox repair tool(scanpst) is the best tool that can be used when you are finding any difficulties to connect your inbox folders or pst files or it is reporting that your Inbox folders or Outlook PST file may be damaged in Microsoft Office Outlook 2000 (or higher).Scanpst is a tiny tool installed by default when installing Microsoft Office 2000 or higher.
PST files or Personal Folder Files are used by Microsoft Outlook for storing Outlook data, including mailbox files, email folders, contacts or any other personal data related to Microsoft Outlook.
By default, Microsoft Outlook stored these PST files at the following location:
"C:Documents and Settings\USER_NAME\Local Settings\Application Data\Microsoft\Outlook",
where USER_NAME is your Windows logon name.
The default PST filename for your active mailbox is Outlook.pst, while the archive file is stored as archive.pst.
"Before doing any types of repairing pls keep a back up of the pst files"
Using Inbox repairing tool
By default, Microsoft Outlook will install the Scanpst.exe file within your Program Files folder, in 'C:\Program Files\Common Files\System\MSMAPI1033'.
If you can't find the Inbox Repair Tool, you can download it from here then copy it to the above folder.
Make sure Microsoft Outlook is not running when you try to run the Inbox Repair Tool. When starting it, you should see the following screen:
If you get an error message like the following one:
then make sure you copied the Scanpst.exe file to the right location. If you still have problems running it, then search your hard disk for a file named "CNFNOT32.EXE" then run it: it should unpack and copy the Scanpst.exe file to its default path ('C:\Program Files\Common Files\System\MSMAPI1033').
Once you started the Inbox Repair Tool, use the Browse button to select your personal PST file. Remember, its default location is "C:Documents and SettingsUSER_NAMELocal SettingsApplication
DataMicrosoftOutlook",(It can be vary depending on how where you configured the pst files). where USER_NAME is your Windows logon name. Then click on the Start button. When the scanning process is done, you should see a notification screen like the following one:
Make sure you mark the checkbox for making a backup of the scanned file, then click on the "Repair" button. When this process is done, you should be able to properly start Outlook and use your recovered personal Outlook folders
6answers
Outlook problem
Close outlook
delete the follwing registry keys
Start > Run > Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins
3/30/2021 5:52:20 AM • Microsoft... • Answered on Mar 30, 2021
10answers
Need help recovering a corrupt .pst file for Outlook 2003
Here is an advance tool to fix and recover the data from damaged Outlook .pst file: Try Outlook PST Repair Software
7/14/2020 4:32:08 AM • Microsoft... • Answered on Jul 14, 2020
2answers
How to increase size of pst file
The size will automatically increase. But actually you don't want it to be too big as it can slow things down and also increase the risks of corruption and problems.
Better to split the PST file if it becomes too big.
5/23/2019 7:53:56 AM • Microsoft... • Answered on May 23, 2019
2answers
Just received new Att email account with U-verse
If you looking for POP3 SMTP Mail Servers then it would be
AT&T WorldNet incoming mail server: postoffice.worldnet.att.net
AT&T WorldNet outgoing mail server: mailhost.worldnet.att.net
or
incoming mail (POP3) -> ipostoffice.worldnet.att.net
Just for POP, I think should be somethinnd like
[email protected]
or
pop.att.yahoo.com
Incoming Mail Server (POP3):
Host Name: ipostoffice.worldnet.att.net:995
User Name: [email protected]
Good luck
11/13/2018 9:12:06 AM • Microsoft... • Answered on Nov 13, 2018
I am trying to use Yahoo Autosync with my Outlook
Do you use iMap on accessing Yahoo! from Outlook 2003?
1/25/2018 10:49:00 PM • Microsoft... • Answered on Jan 25, 2018
I can't open a word document saved to my desktop.
Drag your Word document on your desktop on top of the Word icon on your desktop. Or you can right click the Word document on your desktop and the click "open with" and choose Word.
1/14/2018 8:02:49 PM • Microsoft... • Answered on Jan 14, 2018
2answers
Omegle download . windows 7 ultimate
12/26/2017 4:50:50 PM • Microsoft... • Answered on Dec 26, 2017
2answers
Outlook 2003 restores deleted email files
Thats very strange,
Please open your outlook 2003. Then go on Deleted items, Rt click on properties.
Then check the option if you have done Restore defaults, then uncheck it.
Regards
ELLIN
6/28/2017 11:12:22 AM • Microsoft... • Answered on Jun 28, 2017
2answers
Microsoft Outlook 2003 error.
Did you copy this pst onto your desktop from a CD? If so, then select the properties of the file and turn off theRead Only check mark. To select the properties, justright click the file and select "Properties". Also u can find info here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/667-how-can-i-repair-%E2%80%8Boutlook-file Or you can try a tool called Outlook Recovery Toolbox http://www.oemailrecovery.com/outlook-recovery.html
6/19/2017 10:54:41 AM • Microsoft... • Answered on Jun 19, 2017
2answers
Sometimes when I try to open Outlook 2003 in the
Outlook is actually running in your system.Do following steps.
Press Shift+Ctrl+Esc -> You will see the windows task manager.
In application tab you can see Outlook task.If its status is showing 'Running'. Then select that outlook task and click on Switch o.Outlook should open now.
And is Status of the task is showing 'Not Responding' or you cant see the outlook task then go in 'processes' tab.In this you will see a process named 'Outlook.exe',select that process and click on ' end process' and then reopen the outlook.It will work.You dont have to restart your machine every time.
And also do repair outlook.for this open outlook and click on help tab and select detect and repair' option.this will repair your outlook.
3/19/2016 11:29:03 AM • Microsoft... • Answered on Mar 19, 2016
3answers
Ho do I fix outlook 2003?
Outlook 2003 supports Unicode file format so you should try any utility which supports this one file format. At basic level, you should try ScanPST.exe. If it doesn't give expected result then you can go through Microsoft certified PST repair tool.
12/29/2015 6:13:26 PM • Microsoft... • Answered on Dec 29, 2015
Microsoft Outlook 2003 for PC Logo
182 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
ho fix outlook 2003
  • Computers & Internet
