20 Most Recent
Pioneer DEH-1700 CD Player Questions & Answers
CD Player does not work
I believe the extraction keys are more or less thin metal shims that push the locking tabs down and prevent the tabs from stopping the removal of the stereo while also acting as catches that allow you to simply insert the keys and then pull on the keys to remove the stereo.
If you do not have the right keys, you should be able to make simple metal shims, push them into the left and right sides between the stereo and the mount, once in place you will have to pull the stereo out manually instead of using the keys.
No Power
You also must make sure that it is grounded as well.
If you need more help, let me know and please tell me how you were able to determain that it has power going to the radio. Which wires did you check and how did you check them.
Sometimes having the antenna plugged in will give you a good enough ground to at least check the radio. Most cars have the antenna ground connected to the chassis but not all. This is not intended as a permanent ground.
If all wiring is correct and no fuses are blown, yu may just have a defective radio that needs service.
If I can be more help just let me know.
Dave
Will the pioneer deh p3100ub
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 ModelsSee Figure 4
Removing the radio will require removal of the front part of the center console.
The
original equipment radio has a coded theft protection circuit. Before
beginning removal, be sure to know the code for re-installation. The
code is erased whenever the battery is disconnected or the No. 32 (7.5A)
fuse from the under hood fuse/relay box is removed. When power is
re-connected, the word "CODE" will be displayed and will require entry
of the 5-digit code for that particular unit.
WARNING
All SRS wire harnesses are covered with a yellow insulation. Read
the SRS precautions found in this section and install the short
connectors as described.
Disable the SRS system as described in this section.
Remove the center instrument panel by removing the four philips screws on the top and sides.
Disconnect the 4-pin connector from the cigarette lighter.
Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
Carefully pull the radio/cassette player out.
To Install:
Plug in the 16 pin connector and install the two retaining screws.
Plug in the antenna lead, the cigarette lighter and carefully install the unit.
Install the center instrument panel. Re-connect power to the car,
and enter the 5-digit theft protection code for the radio/cassette
player.
Enable the SRS system.
Free Pioneer DEH 1700 Car
You can download and print the instruction manual in PDF format by clicking this
link.
For installation manual,
click here
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
I have aquired this unit, and when I turn it on,
I would go thru the menu functions to be sure the speakers are turned on first.
I would also check the pre outs to be sure they are functioning , then maybe just use them (plugged into an exterior amp).
How do i set the clock on my DEH-1700?
Toddakins05
To set the clock on the DEH-1700
1. Press SOURCE and hold unitl the unit turns off.
2. Press AUDIO and hold until clock appears in the display.
3. Press <- or -> to select the segment of the clock display you wish to set.
4. Press + or - to set the clock.
Note to cancel clock settings press BAND
Hope this helps
Issken
How do i change the time?
First thing to do is press the "source" button and hold until the unit turns off. Next, press "audio" and hold until clock appears in the display. Then, press the arrows to select the segment of the clock display you wish to set. Now, press + or - to set the clock. To cancel clock settings, press "band". You can also cancel clock settings by holding down "audio" until the unit turns off.
