20 Most Recent
Acer eMachines 3502074 Netbook Questions & Answers
How do I turn on the webcam
Hi ken hamil886
You will need to go to either Yahoo, Netmeeting or some softwear program that allows video chat...then your cam should work
Please take time to rate me
My netbook's touchpad doesn't respond...
Try reinstalling the driver for the touchpad by going to:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=2262
If that doesnt fix your problem it could be anything from bad hardware, to a virus.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
Acer aspire acc 603g uw30 turns on but turns back off. Help
This issue could be caused by several factors, including:
- Overheating - check if the laptop's fan is working and if the vents are clear of dust and debris.
- Low battery - if the laptop is not plugged in, try charging it.
- Corrupted software - try performing a hard reset on the laptop or booting into safe mode and running a virus scan.
- Hardware failure - if none of the above solutions work, the problem could be a hardware failure such as a failing battery or a damaged power supply. Contact Acer Support for further assistance.
