The best free all-around photo management program is Picasa ( http://picasa.google.com ).The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo management program.
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
You may download a copy of the manual here. The self-timer instructions are buried in the "Setting the Drive Mode" section on page 45. Set the drive mode to the desired delay.
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Press the MENU button to bring up the menu. Use cursor-left/right to select Setup (the hammer icon). Use cursor-up/down to select "Memory Kit" and press cursor-right. Use cursor-up/down to select "Copy to Card."If you need a manual, you may download a copy here.
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:And here's a video summary of the steps:
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.And here's a video summary of the steps:
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
you are still in warranty period. you can bring in back to store and tell them what happened, they will send it to a service center, and you will get it repaired or you will get a new camera
Click on read me first and read it. Then, click(sometimes you need to double-click) on user guide. If it does nothing, drag and drop it into your desktop. Do the same with polaroid studio and the video editing software. Decide for yourself if you want the facebook, twitter, and you tube.
The lens assembly is jammed or defective. Check to see if the camera is still under warranty, if not your best bet is to buy a new one - repairing these devices is difficult.
It's configured in the drive mode menu. From the record menu, select drive mode. Use arrows to move through different options. The stopwatch with a "10" in it is a 10-second self timer.
See pp 45 of the manual: https://images-na.ssl-images-amazon.com/images/G/01/00/00/10/67/62/13/1067621330.pdf
