20 Most Recent
LG M1962D Monitor Questions & Answers
What is combination for entering service menu on
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
5/3/2016 7:13:13 AM •
LG M1962D...
Answered
on May 03, 2016
Fallo en pantalla v3.16.0
hola, la pantalla de mi tv se ha quedado en blanco y un codigo que pone v3.16.0 recorre la parte superior de la pantalla. que devo hacer?
2/19/2013 11:11:28 PM •
LG M1962D...
Answered
on Feb 19, 2013
Where can i find a driver for LG Flatron M1962D?
If you are using it as a computer monitor, it does not have a driver, it relies upon your video card to have the compatible format. This is consistent when using an HD TV as a computer monitor. So Identify your video card, download the driver, even if it is an older operating system, the driver will still work if you are on the same basic architecture- 32 bit versus 64.
1/29/2012 5:58:32 PM •
LG M1962D...
Answered
on Jan 29, 2012
Can i play movies as
The USB port on this monitor is just the USB hub than expands your PC USB port to the monitor (USB port of the PC will have to be connected to the USB in of the monitor). It is not a stand alone USB port.
2/17/2011 5:51:40 PM •
LG M1962D...
Answered
on Feb 17, 2011
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
