20 Most Recent Brother MFC495CW Questions & Answers
2answers
Printer offline
Go that manufactured web page and download the newest software for your printer. Also contact apple and explain the issue. I might be that printer is not compatibly with mini mac operating system. I hope that helps. Also how are connecting the printer to your mini mac are you connecting it though usb or though the computer network? Thats another factor to think about.
7/30/2019 12:14:06 PM • Brother MFC495CW • Answered on Jul 30, 2019
3answers
Need a driver to install
Hi You can download driver from below link. Click here Select your os and download driver then install. Let me know if you need further assistance. Thanks for using FixYa.
10/4/2018 4:51:35 AM • Brother MFC495CW • Answered on Oct 04, 2018
0answers
Unable to Clean 5A
The machine does not work due to a paper jam or some sensor problem.Clear the paper jam, try to clean the sensor on the top of the printhead.
8/7/2016 7:26:51 PM • Brother MFC495CW • Answered on Aug 07, 2016
Mfc-495cw will not print black
If this is an inkjet that the nozzle for black is probably clogged and needs to be cleaned with a q-tip and rubbing alcohol.
8/18/2012 4:42:11 AM • Brother MFC495CW • Answered on Aug 18, 2012
0answers
My printer is not receiving
If your Printer is turn on, please turn it off. Wait a few minutes and then turn it on again.
Verify that your Wireless button is pressed and is broadcasting on the printer.
Go to your computer and check to see if you can see your printer in the wireless devices section.
If so, try to connect. And then try to print something.
If that does not work, uninstall the printer from your computer. Reinstall it. It should automatically find the broadcasting wireless signal, and connect.
2/28/2011 5:18:15 PM • Brother MFC495CW • Answered on Feb 28, 2011
Trying to print photos from
pull out the paper tray. depress the blue button located to the right of the photo paper insert slot and slide the entire top section of the paper tray forward until it latches into place. be sure to place your photo paper finish side down. the printer will automatically recognize the paper size and select it for you by default. i assure you this will solve your problem. heres a link to the manual. the illistrations you need are located in chapter 2 page 13 and 14. please leave a testimonial on my page to show appreciation. thanks.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_495CW_EN_1855.PDF
12/21/2010 2:54:26 AM • Brother MFC495CW • Answered on Dec 21, 2010
Driver for windows 7
heres the link to your multifunction printer. be sure to uninstall any printer software installed defaultly by windows. then make sure your printer IS NOT plugged in to the usb port until the driver application file tells you to plug it in. if you leave it plugged in the printer will not work, un less you reformat your computer again and start from scratch. if you have any questions fell free to call me 765-570-4602
12/20/2010 11:40:06 PM • Brother MFC495CW • Answered on Dec 20, 2010
Hi, I've changed my Brother printer ( MFC-495CW)
this happened to me, too. printer starting using all of my yellow ink.
The ink container was the problem, defective. it took several changes for it to print in black again...5-10 cleanings.
make sure the black cartridge is not defective by trying another one in it's place. if you can, use the yellow for the black slot, then switch back a few times ( I tried to re-install the drive, but the in was the problem). Good luck.
11/28/2010 10:43:44 PM • Brother MFC495CW • Answered on Nov 28, 2010
I placed a picture over
you do not change any setting on your computer and on your machine: the machine work as a scanner, if you click the scan Botton, you should go to scan utility on your computer and click the scan command to receive the numeric format of the original image placed on the glass, if you need help about '' how do you scan a documemt '' : 1) click the start botton 2) go to control panel 3) click twice on the scanner and photo 4) the assistant will guide you to scan your photo. if my solution helped you don't forget to vote.
11/10/2010 11:26:07 AM • Brother MFC495CW • Answered on Nov 10, 2010
Como deshabilito el informe de impresion de brother mfc-j1010dw
Question edited and translated to English. We are a North American website, we only speak English. You can't https://www.google.com/search?q=Brother+MFC-J1010DW+%22disable%22+print+report ..
3/23/2024 1:39:34 AM • Brother Office... • Answered on Mar 23, 2024
Brother MFC-J985DW Colour Inkjet Multifunction Printer. Why doesn't the paper jam message go away?
Question edited for clarity. 985 or 895? Usually because the jam hasn't been cleared or the machine hasn't been reset. Remove the paper tray an open the cartridge bay. Open the rear paper door, check underneath. This machine has a lot of paper scraps in it. :>D
3/17/2024 12:10:58 AM • Brother Office... • Answered on Mar 17, 2024
How Do I Fix Brother Scanner Error Code 2023?
https://help.brother-usa.com/app/answers/detail/a_id/74629/~/error-2023---usb-communication-error "Error 2023 - USB Communication Error" This typically indicates a communication error between the Brother machine and the computer. 1. Turn off the Brother machine, wait 15 seconds and then turn the machine back on. 2. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, go to step 3. Warranty Calculator to check the status of your machine's warranty. If your machine is out of warranty, we offer a repair option. Please contact Customer Service for warranty or repair options. - If the USB port appears undamaged, go to step 5. step 8. here for instructions. 9. Download and reinstall the Scanner driver, which includes the DSmobileCapture software. Click here for instructions. Don't reinstall using the DVD. Instead download the latest version of the software from http://support.brother.com. 10. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, then the issue is likely caused by a software conflict. If you have another computer, try installing your machine on that computer and scanning. This will determine if there is a problem with this computer. If after troubleshooting you are still unable to scan, contact your computer manufacturer for additional support.
2/20/2024 2:59:01 AM • Brother Office... • Answered on Feb 20, 2024
What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue: Check for a dial tone: 1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone. If there is no dial tone, press Hook again and proceed to step 2. If there is a dial tone, press Hook again and move to step 4. 2. Verify telephone cord/line connection: Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side). If the cord is already in the LINE port, proceed to step 3. If it's connected to EXT, remove it from there and connect it to the LINE port. Press Hook and check for a dial tone. If still no dial tone, proceed to step 3. If there's a dial tone now, move to step 4. 3. Test with a known working telephone: Disconnect the telephone cord/line from the LINE port on your machine. Connect it to a known working telephone and test for a dial tone. If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider. If there's a dial tone, reconnect the cord/line to the LINE port on your machine. Press Hook and check for a dial tone. If still no dial tone, consider warranty and service options. If there's a dial tone, proceed to step 4. 4. Remove splitters or other devices: Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack. If yes, remove them for testing purposes. After removing any devices, continue to step 5. 5. Adjust Compatibility settings: Press Menu/Set. Navigate to Miscellaneous > Compatibility. Choose Basic (for VoIP). Press Menu/Set and then Stop/Exit. 6. Send a fax: Insert the document face down in the Automatic Document Feeder (ADF). Adjust paper guides to fit the width of your document. Enter the fax number using the dial pad. Press Fax Start. Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance. If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider: Epson WorkForce WF-2750DWF: This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen. Features: Print, copy, scan, and fax. Scan resolution: 1200 x 2400 dpi. Dimensions: 16.73 x 14.17 x 9.06 inches. Weight: 14.55 lb. It's a budget-friendly choice for home and office use. Brother MFC-L6800DWT: A high-speed monochrome laser fax machine with additional features like printing and scanning. Ideal for small offices. Check out its performance and ease of setup. Canon TR8620: A multifunctional all-in-one printer, copier, and fax machine. Offers versatility and functionality for various tasks. Consider it if you need a reliable fax solution
2/15/2024 2:09:59 AM • Brother Office... • Answered on Feb 15, 2024
Brother MFC495CW Logo
40 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
unable clean 50
  • Office Equipment & Supplies
