20 Most Recent
The Times ROYAL TC100 TimeMaster Time Clock Questions & Answers
Can not fix correct time
Go to:
http://www.royal.com/drivers_manuals.htm and towards the bottom of the screen pick timeclocks and the model (TC100). If you have a Pop-Up Blocker, hold the <ctrl> key down while choosing the model. You will get a new window and there you have a 22 page manual on how to set the time and replace the ink.
How to fix the clock in and out
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.Press Setting to choose one of the following Print Methods.The TC100 has two settings for print activation: Manual or Automatic1 = Automatic (default setting) - The TC100 automatically prints when the timecard is inserted.2 = Manual - After inserting the time card, press the Print Button to activateprinting.Press Select to confirm the Print Method chosen. Press Mode to return to normal operationalmode.Step 3: The control knob corresponds to Step 4: Insert the time card. The time theformat of the time card. Turn time will automatically print in thethe control knob to select the desired selected row.day and print row. I hope this help let me know : - )
I need a time master
I need to know how to adjust the timeclock to make it punch in/out on the proper line, thanks
Hi, I set the year
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting buttonuntil the correct hour is displayed. Press Select to set the hour shown.The Minutes will blink. Press Setting until the correct minutes are displayed. Press Selectto set the minutes shown.The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.The Year will blink. Press the Setting button until the desired year is shown. Press Selectto set the year shown.The Month will blink. Press Setting until the correct month is shown. Press Select to setthe month shown.The Day blinks. Press Setting until the correct day is shown. Press Select to set the dayshown.Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.Press Setting to choose one of the following Print Methods.The TC100 has two settings for print activation: Manual or Automatic1 = Automatic (default setting) - The TC100 automatically prints when the timecard is inserted.2 = Manual - After inserting the time card, press the Print Button to activateprinting.Press
normal operational. hope this work for you best regards happy holidays :
Royal Time Master TC100 Time
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting buttonuntil the correct hour is displayed. Press Select to set the hour shown.The Minutes will blink. Press Setting until the correct minutes are displayed. Press Selectto set the minutes shown.The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.The Year will blink. Press the Setting button until the desired year is shown. Press Selectto set the year shown.The Month will blink. Press Setting until the correct month is shown. Press Select to setthe month hope this help : - )
I need a manual for this product.
this is the link so you can download the manual hope this help : - ) Happy holidays http://www.royalsupplies.com/drivers_manuals.htm
Will not print date 11-19 sample
