20 Most Recent Pioneer PureVision PDP-503HDE 50 in. Plasma Television Questions & Answers
I have my ps3 connected to my pdp-503hde plasma.
play station start in 800x600 and then boot to your recommended settings the tv picks up the signal from the ps3 to change to these settings if the signal is not being changed then it could be a problem with the cable and usually pulling it out while its on and then back in again sorts this out.
9/9/2017 1:40:23 AM • Pioneer... • Answered on Sep 09, 2017
No picture but is back light, the remote doesn't work or any buttons on machine, only turns on by power button on screen which flashes twice, waits, does it again a couple of times and then turns off!
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
8/15/2015 1:13:38 PM • Pioneer... • Answered on Aug 15, 2015
2answers
Don't remember password
You should be able to call the manufacture and they can give you a temporary pass code
12/14/2012 6:03:00 PM • Pioneer... • Answered on Dec 14, 2012
What media box do i need for my pdp 503pe?
Kindly go through operation manual of every device and follow guidelines step-by-step. There will be description of what type of devices will work with the TV.
8/6/2012 7:27:37 AM • Pioneer... • Answered on Aug 06, 2012
3answers
I have an E01 error message what is it and how do
I have an E01 error message what is it and how do"tv pioneer pdp-503pe"
1/20/2012 2:45:25 AM • Pioneer... • Answered on Jan 20, 2012
My plasma PDP-503HDE exploded: a
hi,
You have to check the power supply board. Its a common problem with the power supply of the Pioneer PDP. As it is using smd coponnents there is no repair possible with the power supply . You have to replace the power supply board with a new one. You can find the part number in the board. Serch with the part number to find a new board.
OK
9/24/2011 11:54:25 AM • Pioneer... • Answered on Sep 24, 2011
I don't know what the
From Googling it seems to be the power supply problem.
http://www.fixya.com/support/t317402-pdp_5030
Most failures in PLASMA TV are due to failed power supply, Y and Z sustain boards. So check all three boards for shorted circuits, blown fuse and caps. You may want to download any one of the PLASMA TV training manuals to learn about PLASMA TV since the operating principles are about the same.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find. Please leave rating if it helps.
1/21/2011 6:18:54 PM • Pioneer... • Answered on Jan 21, 2011
Is my Pioneer 50" plasma PDP-503HDE HD ready?
Yes it is but upto 720P only. It is not full HD(1080P).
1/10/2011 5:35:13 PM • Pioneer... • Answered on Jan 10, 2011
Hi my Pioneer Plasma #
I have this same problem someone help
1/10/2011 1:10:02 AM • Pioneer... • Answered on Jan 10, 2011
2answers
Screen wont turn on - flashing green light
hello mark ,just had the same problem with my pioneer pdp503 hde, fixed myself and very easy to do. its the power supply board ,got mine on ebay for 109 pounds.was very easy to fit.it is the big silver panel in the center just unscrew and disconnect cabels. very commen problem in pdp . mark doran post again if you want more info
11/2/2010 3:11:38 AM • Pioneer... • Answered on Nov 02, 2010
E-O-1 ERROR IN PDP 503 HDG
In the process of having mine repaired at a cost of AU $1280.00.
It is a problem with the media box boards.
11/2/2010 3:09:22 AM • Pioneer... • Answered on Nov 02, 2010
No sound on tv Help my mother in law is very
Check that all of the cables are plugged into the back of the TV. Check over your connections and the TV settings, I'm assuming you do have satellite or cable. Make sure that the cables you screw in are all the way screwed in and all the color coated cables are into the right color outlet, especially the red and white ones. And just to be sure, check if you accidentally hit mute.Even if you have an S-video connection it is suggested plugging in the audio cables if all else fails.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
11/1/2010 7:21:52 PM • Pioneer... • Answered on Nov 01, 2010
I seem to have lost audio from all inputs, any
Televisions receive sound through the tuner then amplify using an audio chip.  Both are prone to cold solder joints  when they are under a year old over aging solder joints when over 10 years old.  Your audio chip may have failed.  Hopefully your tv is still under warranty.
11/23/2009 12:52:04 PM • Pioneer... • Answered on Nov 23, 2009
Plasma e01 error
Hi. Had all the symptoms with my Pioneer 43" plasma with RO3E receiver that have been previously posted. I got so fed up with it turning itself off that i decided to take the top off the receiver and look for the dry solder joints on the power supply board that some have posted to have cured the problem. I removed the power supply board (which involved removing an interface unit which is mounted above it) and found no issues. I then proceeded to remove the switch board which is placed in front of the power supply board. When i removed the electrical connector which i found not to be fully inserted, i noticed that there was a brown burnt stain in the middle of the connector plug indicating a possible poor connection. I removed the electrical connector from the unit completely (the other end connects to the adjacent board with the fuse on it) and cleaned the connector plug with electrical cleaner and re-inserted it into the receiver and built everything back up. I am happy to report that the tv starts up first time every time and has not turned itself off since. I have included a picture of the offending plug in its built up state (it is the one with the row of black wires with one red wire). Do not attempt to do this unless you are suitably qualified.
5/20/2009 9:43:01 AM • Pioneer... • Answered on May 20, 2009
Can't get full streaming to pioneer plasma from mac book air
Hi
Do you recall when Steve Jobs introduced a little white box called the Apple TV which allowed his products, both Software like TV shows and films from iTunes, to connect to digital TV displays?
Within that little box was the solution to problems their engineers foresaw.
You can connect your mac book to the Apple TV box and achieve the advantage of components therein that solve the problem you have by virtue of disk swapping on the 40GB or 160GB drive.
If you don't want to purchase an Apple TV and subscribe to the services for any reason, you should, if available disk space is available on your macbook, increase your swap space on the drive you have or on external drives so as to accomplish flawless streaming.
If you need help on that, let me know.
3/28/2009 12:16:20 PM • Pioneer... • Answered on Mar 28, 2009
2answers
PIONEER 503 6 YEAR OLD SWITCHING OFF
yes my friend that's fixable. the ph capacitor that is located in horizontal section is leaking.
3/22/2009 2:46:56 PM • Pioneer... • Answered on Mar 22, 2009
Pioneer PureVision PDP-503HDE 50 in. Plasma Television Logo
38 questions posted
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
no picture but back light remote doesnt
  • Televison & Video
