20 Most Recent
Microsoft Works 8.0 for PC Questions & Answers
I have a document saved in microsoft works
download free open source Lebre Office, open your document and save as any type you wish, it is 100% compatible with all Microsoft documents from word and works , office or works files and saves in all platforms including PDF
How do i stop video straming interruptions?
Slow internet access
Will cause video interruptions or buffering - buy a faster internet connection speed or reduce the number of applications or people access the internet while streaming.
If your computer is slow, or has tasks which are taking a large amount of processing power to execute it can cause streaming to stutter.
Can't print more than one
When you want to send a document to the printer, open the configuration of the printer and select the appropriate number of copies. Explore the printing options of your printer.
When I insert disc (microsoft works suite) the
For security reasons, the Autorun feature for the CD drive may be
deactivated. Just use Windows Explorer to explore the CD and locate a
file that runs the installation procedure. It may be called Setup,
Installation , or just Works Suite.
How to create mailing labels in Microsoft Works
With a Microsoft Works Word document open, select: Tools>Labels>(the list of available label types will pop up, select the label sheet you're using) then select: Tools>Mail Merge>Open Data Source...
Don't know how it could be simpler.
In the add or
Sometimes the software under Windows and using the Windows uninstall option is not working properly. To "beat" this fact I'd suggest you to download and to install REVO UNINSTALLER on your machine. It's free and not only it will UNINSTALL the software, but it will clean up all the remnant things after the uninstall will be done (like the REGISTRY allocations).
The FREE REVO UNINSTALLER is
HERE.
Before you can perform printer related tasks you
If you don't have a physical printer, youcan just install any printer from the drivers available in Window. Go to Start- Control Panel - Printers and Faxes and then click on Addprinter, then on the next screen disable the checkbox with Automaticallydetect and install my Plug and Play printer, click next, you can leave thedefault LPT1 as the port for the printer, click next and then on the inthe new window you can choose a Manufacturer and a Model for yourprinter. Choose for example the HP as the manufacturer and some deskjetprinter model and then click next, leave the name of the printer as is andclick again next. In the final page disable the option to print a test page bychecking the No option. Click next and then Finish. After the driver isinstalled you must see the name of the printer in the Printer and Faxeswindow as the Default printer. Now you can use the option page previewin any software with this option enabled. If you move your work later onanother computer with a physical printer attached and you want to print yourwork there, it is best to use the same printer driver for your computer. Ifnot, any printer will be ok for just previewing.
Microsoft Word document not printing correctly.
You can get a good copy by downloading OpenOffice here:
http://download.openoffice.org/other.html
It's a free full blown office suite that is better than MS Office (in my opinion). the copy and paste your document into open office writer. It's compatible with virtually every version of every major office suite ever made. Then when you have your copy you can uninstall it if you choose to. It will work. You can even turn it into a pdf if you want to.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
How do I sort text in a document
There should be an icon in the toolbar that has an "A" and a "Z" and arrow going up or down. Highlight the text you want to sort and click that icon. If the icon is not there you might have to search Help to find where you can choose the sort option.
Try to open documents in works 8 and get a
Try creating a NEW works document, save it. Close works, open it direct.
If the problem still occurs, uninstall works and re-install should solve your dilemma.
Make sure you've got the serial / product key before you uninstall.
If you don't have it written down you should be able to use
this program to extract it.
