20 Most Recent
Brother CS-6000i CS6000i 60-Stitch Computerized Sewing Machine with Wide Table Questions & Answers
My LCD is black and cannot be read.
First, check to be sure the Display has not been dimmed to the point where it is black.
If that is not the case, then a computer component has probably failed.
My straight stitch is not perfectly straight, what can I do?
1. Put a piece of paper on the sewing machine w/o thread. Sew for three inches.
2. Notice the needle holes are straight with the feed dogs. The pressure foot is not in line with the holes.
3. With the pressure foot down loosen the pressure foot pressure to it's lowest amount.
4. There is a screw on the arm that needs to be loosened. Afterwards, adjust the arm until the foot is parallel with the feed dogs. Tighten screw.
5. Try sewing again on the piece of paper to check for accuracy on being straight.
6. One other check is to insure the feed dogs have even wear.
How to troubleshoot without a manual
Yes, Brother has a free download, Go to this site:http://www.generalmanual.com/Home-Sewing-Embroidery-Machines/Brother-CS-6000i-Sewing-Machine.htm and you should have what you need. You also might have the bobbin pushed to the right, in the wind position. Is so, push bobbin to the left and all should be fine.
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
