20 Most Recent
Visioneer OneTouch 5800 Flatbed Scanner Questions & Answers
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
9/22/2015 2:32:12 AM •
Visioneer...
Answered
on Sep 22, 2015
How to unlock Visioneer OneTouch 5800 Scanner
i was getting this message when i was using the wrong power supply, i used a diffrent power supply and restarted the computer and it no longer says it, so i couldnt tell you exactly which one made it work, but now i get a box telling me i dont have enough disk space??? any anwsers for that??
12/9/2012 10:26:04 PM •
Visioneer...
Answered
on Dec 09, 2012
Help...my visioneer onetouch 5800 usb
From
this official link you can get the drivers for your scanner. Note that this scanner is not compatible with Windows 7.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
6/17/2011 7:38:00 AM •
Visioneer...
Answered
on Jun 17, 2011
Power adaptor?
If you need a replacement, you have two choices. Visioneer no longer makes this scanner, but they do offer replacement power adaptors. They run about $20 plus shipping. It may be quicker (and cheaper) to look on the scanner (maybe on the bottom or on the back, probably beside the power jack) or on the current adaptor itself and see what the power rating is. It will say something like "6 VDC, 1A" or "5.5 VDC, 3-5A". These are the two power ratings you need. VDC is the DC voltage, and A is the amperage. You can take the power adaptor to a local Radio Shack or similar electronics shop, and they'll help you with an appropriate adaptor. You may also be able to find an appropriate adaptor at a large electronics store (like Best Buy) or a large discount store like Wal-Mart or Target. Just go to the electronics section.
A small speciality shop will probably take the adaptor and give you the choice of one or two that will work. In a larger store, you may not get as much help, so you just want to match both power numbers on the package, then make sure the plugs on the end of the power cords match, so the new one will fit your scanner (universal adaptors often include several tips that can be put on the end of the power cord; just make sure one of them is the same size and shape as yours).
3/6/2011 4:32:19 PM •
Visioneer...
Answered
on Mar 06, 2011
Visioneer 5800 power supply
My power supply for my Visoneer 5800 appears to just have kicked the bucket... And, I stumbled across your post in a search for a replacement.
Anyhow, here are the specs off mine:
YHI Power Adaptor
Model: YS-1015-U12
Input: 100-120V 60HZ, 0.45A
Output: +12VDC/1.25A
12/5/2010 12:25:11 AM •
Visioneer...
Answered
on Dec 05, 2010
I have no cd for
If you use windows xp or earlier version of windows you can download driver from below link.
Click here
Let me know if you need further assistance.
Thanks for using FixYa.
10/3/2010 5:28:00 PM •
Visioneer...
Answered
on Oct 03, 2010
When I scanto Paper Port, I get a black and white
You can change colour option is scanner software from where you scanned.
For that before scanning open that software then go to it's settings and change scan option to color if you want color.
9/17/2010 2:34:03 AM •
Visioneer...
Answered
on Sep 17, 2010
Have HP scanjet loaded software and driver but it
Having re-read your post it seems you have a visioneer scanner and installed HP scanjet drivers so this would definitely be an issue.
Ok, unplug usb lead between scanner and pc.
go into add/remove programs and remove any scanner software that may be showing.
load correct scanner driver (preferably the latest version from the manufacturers website).
plug in scanner usb lead when prompted and turn scanner power on.
It should then install correctly.
If usb stuff starts playing up it's usually easier to unplug it, uninstall it then re-install it using the latest drivers from the manufacturers' website. Don't just stick the disc in and re-install. Can save hours of messing about.
4/28/2010 9:02:20 PM •
Visioneer...
Answered
on Apr 28, 2010
